Question about Dacor DMO24SS Microwave Oven
The LED on the control panel only partially works.
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Digital read out only partially working..
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 14, 2010 | Dacor DMO24SS Microwave Oven
The led readout is not readable, the numbers are just partially lit
The control board needs replacing. The cost is usually 75 dollars and up just for the board. You can order it from your neighbourhood appliance parts store. Just give them: Manufacturer, Model, Serial no's.
Changing the board can take about an hour. It is an easilly replacable module.
Jan 20, 2010 | Sharp R-530ES Microwave Oven
Re: Oyster Micro-wave 1000 watts-LED Panel not working correctly.
you probably have to replace the keypad control, or you could try checking the connections to the keypad by taking the cabinet and checking the connections to see if they're loose.
Sep 30, 2009 | Microwave Ovens
Microwave works, numbers on display are only partially visible.
sound like a bad Key pad. contact sharp with modle number and the can tell you what you need.
Jul 27, 2009 | Sharp R-1502 Microwave Oven
Microwave LED only displays partial numbers
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
We really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the attached photos.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jun 10, 2009 | Hotpoint JE740WY/GY Microwave Oven
MH1150XMT-0 (whirlpool) partially dead control panel
In order, I would suspect:
- it needs a reset
- door switch or door switch mount trouble
- your keypad is failing
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it so I can give you some advice on the other two probable causes.
Aug 23, 2008 | Whirlpool MH1150XM Convection/Microwave...
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
Dacor DMO24SS Microwave Oven Logo
27 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
