I keep getting red dots covering basically the whole screen. i can still see what im doing but it gets incredibly hard to see the screen etc. the thing is the laptop is literally 2 days old!
    Sergeant:
  • 321 Answers
Dude if you have a warrenty then get it checked out now.
Posted on Jan 03, 2011
Left phone in rain for 20 min. Very little moisture in phone and water marks untouched, but touch screen non responsive. Hard reset had no effect.
A phone in the rain for 20 mins is way more than enough time for it to get water inside. There still may be hope, but odds are against it. Turn it off now and take the battery out. Get a hair dryer and blow dry it for about 20 or 30 minutes. Don't over heat it, but keep it consistently hot the whole time. Let it cool and try it again. There is normally a white dot somewhere under the battery. If that dot has turned red, you definitely have water damage that voids any warranty you may have had. Good luck with the dryer.
Sep 03, 2015 | Cell Phones
3 year old Panasonic VIERA TC-P54VT25 screen has a series of horizontal red dots from left edge to middle of screen in lower half of screen. Visible when the picture is dark. Not so visible when the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2014 | Panasonic Televison & Video
My Ipod Touch 4G 8Gb has a screen malfunction in which the screen turns incredibly bright and the bottom half displays a faint copy of the top half. The whole thing basically looks like an old film fliter...
It is possible that your display is faulty or the connector has become loose. To fix this, check whether your iPod is covered under warranty, if not, you'll have to pay, but regardless, you should take it to your local Apple store to get it fixed, immediately. If you have just purchased the iPod, return to the dealer and ask for a replacement.
Jun 29, 2011 | Apple iPod touch
My screen has red dots all over it that won't go away unless I bend it all the way back. How do I get rid of these dots?
when the red dots show up is because the front cover of the screen is a bit loose fron the auctual screen it self!
All you can do locally is take screen off the laptop as try to press the screen from the side corners that maybe works for a litle while then you'll need to get a new one!
Nov 28, 2010 | Sony VAIO CS VGNCS215JP
How to put up a tent- ozark trails 16x12
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
May 20, 2010 | Computers & Internet
Red dots and lines on mobile touch screen
You can try a hard reset on your phone by removing the battery for 30 min and then power it on if lines still exists then it is display hardware problem you may need to change display in the phone ...........
Good luck...
Jan 07, 2009 | O2 Xda Atom
Ps3 freezes at startup screen/ green red dots/lines,
Turn off the PS3 with the switch on the back, then turn back on. wait till the light is solid red then hold your finger on the start button for abount 10 seconds until you hear it beep twice.
It will then ask you to connect a controller via the usb cable and press the PS button. Once you do this it will bring up the reset menu.
Unfortunately the only way I found that solves this is a full system restore that wipes the hard drive completely.
You do however retain and data saved online such as COD stats etc and playstation store purchases with your PSN.
Hope this helps??
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
Shuts off when you touch the touch screen!
Im guessing that your replacement screen is metal backed (the original had a poly-foam backing for a reason) ,,,, when you tap lightly it works, when you press hard your pressing the metal back of the screen onto the mini-board behind it and shorting it out
If you keep doing this you will damage the mini-board, take it back out and cover the metal back with sellotape or masking tape making sure to cover the whole metal back, (dont go up the sides or its impossible to get back into the cover).
Re-assemble as before and if it isnt too late for this you will have a working DS again.
Hope this isnt too late
Oct 13, 2007 | Nintendo DS Lite Console
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
