Question about Polaroid TDA-03211C 32 in. LCD HDTV
My Polaroid TDA - 03211C will no longer turn on. It was exposed to freezing temperatures and wondering if this could have caused a problem? The indicator light will come on when plugged in but will not respond when on/off switch is pushed or the remote is used to turn the tv on.
  • Polaroid Master
  • 1,210 Answers
The freezing may not have helped. But your TV had problems before it was subjected to cold weather. If you can find a hobbiest or a TV tech they may be able to repair your TV. You, by now have failing capacitors in the signal board as the majority of them are here. I don"t specifically remember the values. I think there were several 10 volt to 16 volt 10Mfs caps that are bad and there were three or four that were 25 volts at 470 Mfs. Also there may have been two 50 volt 33Mf caps. These were all in the signal board. The power supply will have two bad capacitors,I don't remember their values. You will need an ESR meter (capacitor checker) to find these. Be very, very careful when you remove these. You can pull the traces off the pcb board if you are not careful and destroy this TV. Thanks for asking and show a few hands of support.
Posted on Jan 03, 2011
Tv turns on then powers down
Try doing a factory reset. Here is a link to the manual in case you don't have one. Hope it helps. http://www.manualowl.com/m/Polaroid/TDA-03211C/Manual/230758
Apr 20, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
TDA-03211c 32 inch Polaroid replaced two capacitors now it turns on runs but shuts off in 10 minutes or so what could it be?
It is having higher voltages in some sections, might be a leaky or open zener diodes. Have you replaced the capacitors with correct voltage and watts rating? This is a case to be handled by a qualified service technician.
Jul 16, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid tda-03211c no picture
I was just looking at my manual for mjne and there is a fuse behind the set in a small plastic box you might check it
Oct 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
LCD screen part number for Polaroid tda-03211c
Replacing the LCD panel in any TV is not a cost efficient choice for the average person. The cost of the LCD panel is usually as much or more than the TV is worth, often times costing as much as a brand new TV. Considering the poor reputation for service that Polaroid had before it went bankrupt, it is best you consider another option since the screen is only one part of what makes the TV. Even if you were to replace the screen, you still would have a TV that was out of warranty without any service support if another part fails.
Sep 14, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
A owners manual for a 27 inch polaroid flat screen
google this owners manual model number: TDA-03211C
Mar 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Oct 23, 2008 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
620 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
