Occasionally when my dryer is running it makes the most awful high pitched screeching noise! Help! Not even sure what to do or look at to resolve this issue.
  • 583 Answers
It'll either be the drive belt that goes around the drum needs replacing or the idler pully that keeps tension on the belt needs replacing. It is usually the belt. This is not a difficult replacement. A generic procedure is to remove the back of the dryer. You should be able to get to the belt to replace it. While you're in there, check the pully for smoothness of operation and that it rotates easily. If it needs replacing also, do it while you're changing the belt. If the belt seems to be in good condition, the pully might just need a drop or two of light oil.
Posted on Jan 03, 2011
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Whirlpool cabrio gas dryer
It could be a bad bearing in the drive motor or on the tub if it is a really high pitch,, or it could be the drive belt on the tub is slipping.
Oct 27, 2013 | Dryers
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Whirlpool Dryers
My armana clothes dryer still works very good, and drys the clothes really well. recently it has started to make this awful high pitch noise. i dont know how old it is. i would like to get it fixed as soon...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Mar 04, 2011 | Dryers
The MDF300AYW dryer screeches at at high pitch when clothes are drying
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 14, 2010 | Maytag Dryers
Makes a scrapping sound when running. It dries okay but it makes that awful scrapping/screeching sound, especially when it reverses
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 20, 2010 | Fisher and Paykel DEGX1 Electric Dryer
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
 Grubhead
Grubhead
