Question about GPS
Garmin c330 touchscreen not working in bottom left hand corner when i try to press it.
  • 1 more comment
  • Anonymous Jul 27, 2008
    mine too stoped working
  • lees13 Jul 30, 2008
    When I touch the screen keys I get another letter comes up on the screen. Like when I touch the letter "D" I get the letter "L" on the screen.
  • spiderwebbtc Apr 02, 2009
    I also have this problem with my StreetPilot 340.
I am having the same problem but on the right bottom screen. i have a 2620
Posted on Oct 12, 2008
I plugged in my Garmin Nuvi 40LM to the computer and got the updates. But my keyboard is still not responding correctly. I push 5 and get a 6 or push T and get a Y. Any ideas?
Try recalibrating the display. Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and hold it there while pushing down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press all of the dots as they are presented. Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display. If this doesn't resolves your problem. then your touchscreen may be defective.
Feb 25, 2016 | Garmin Nuvi 40Lm - Gps Receiver
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 2720 touch the (s) and the (T) responds
You need to recalibrate the touchscreen. Try this: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Go through the entire procedure of pressing each dot as it appears on the screen.
Once completed the Nuvi will display Calibration Complete This will recalibrate your touchscreen to the LCD display.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Feb 11, 2014 | Garmin nuvi 205 GPS Receiver
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Mar 29, 2013 | Garmin nuvi GPS
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Garmin 1450t stuck in loader loading error after downloading maps
Please follow the instructions below to remove the "Loader Loading" message from the unit.
To fix this problem on Windows:
  1. With the nuvi powered off, press and hold the upper left hand corner of the touchscreen with your finger
  2. Continue to hold the touchscreen while pressing and releasing the power button on the device. The Garmin Logo should display
  3. Continue to hold the touchscreen while connecting the device to your computer
  4. After 30 seconds, the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears in My Computer or Computer
  6. Locate the Voice folder and delete the extra Voice files that are not needed
  7. Type ".System" (without quotations) after the nuvi's letter in the address bar
    • For example, if your nuvi appears as E:\ then after typing ".System" in the address bar, it should look like this: E:\.System
  8. Locate the GUPDATE.GCD file and delete it
  9. Safely remove your device from your computer
After the corrupted update file has been removed, the device should work properly. Run the WebUpdater program to update the device's operating software.
To fix this problem on a Mac:
  4. After 30 seconds the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears on the Desktop
  7. Click the GO menu at the top of the computer screen
  8. Click Go to Folder
  9. Type .System
  10. Click Go
  11. Locate the GUPDATE.GCD file and move it to your trash
  12. Empty the trash
  13. Eject the nuvi from the Mac
Jan 06, 2012 | Garmin Nuvi 1450T GPS Receiver
My Garmin nuvi 1390T will unlock the screen without entering all or part an incorrect password. It usually takes a while to pick up the satelite signal. The touchscreen needs to be more responsive to the...
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
The touch screen may need recalibration.
This can be done by pressing and holding the top left corner of the screen will powering on the unit.
Keep pressing the top left corner of the screen until the calibration screen appears.
Use a stylus or the round back part of a pen to press the dots to calibrate.
Once the calibration is done the unit will continue to boot up showing the Garmin screen.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin nuvi 1390T Car GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
GPS Logo
469 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
