Question about TC Electronic Nova Repeater Pedal Guitar
Is the TC Electronic Nova Repeater supposed to retain all of the settings when the power is turned off to it? Mine did and doesn't anymore. Is there a master reset for this pedal?
  • TC Electronic Master
  • 5,603 Answers
The unit should store the data ASSUMING you have done the store, I suspect the unit has an internal backup battery, probably Lithium, which MAY be exhausted.
Posted on Jan 04, 2011
Please help me obtain a TC Electronics BG250 schematic
Try Googling (TC)(BG250)(manual) without parens.
Jan 08, 2016 | TC Electronic Music
Psr s 910 keyboard. Why does it turn on for 5 minutes, then turn off?
Be sure to use the original adapter and still in good condition/normal.
Have you tried, at the time after 5 minutes then turn off, and then you restart immediately, the unit is turn ON again? Or is there a time lag to ON, after power-switch is pressed?
Errors like this one,may be due to defective adapters (works only for a moment, after being hot, stop sending voltage), and can also be caused by damage to the regulator section in PSR910.
To check this, it must open/disassemble the PSR910.
"Do not do this if you are not experienced in electronic repair.
Leave it to the experts."
At Yamaha PSR S950 keyboard, there is a setting "AUTO POWER-OFF" in the UTILITY menu.
This setting function is To prevent unnecessary power consumption. It will Automatically turns the power off if the instrument is not operated for a specified period of time. The amount of time that elapses before the power is automatically turned off can be set (default setting: 30 min.). The setting is retained even if the power is turned off.
At the PSR-S910, this function does not exist.
25916731-0iboo3zhsd2tihqbcqrvolhc-1-1.jpg .
Oct 20, 2015 | Music
Value in ohm of RESISTOR NUMBER R7
That's a tough one...is color bands still readable? If so look it up on the net as metal film and carbon resistors use slightly different bands. Also, if the resistor turned to charcoal then there was a reason and it could be time for you to visit the nearest TC certified service center.
Jul 30, 2014 | TC Electronic RH450 Bass Amp Head
Service manual t.c.electronic G MAJOR
Hello there.
I found Manual for TC Electronic G-Major http://www.tcelectronic.com/media/g_major_us_rev71.pdf , and for C Electronic G-Major 2 http://www.tcelectronic.com/media/G_Major_II_US.pdf
Please rate it if it was helpfull.
Sincerely,
Steve TM
May 29, 2011 | TC Electronic G-Major 2
The wheel of my TC Electronic M-One-XL doesn't work. Everything else works fine, but not the wheel.
The encoder is probably damaged. If the wheel took a hit, that damages them. Neeed to have it replaced.
Apr 22, 2011 | TC Electronic M One Xl Dual Reverb Effects...
DOES A 2003 NISSAN PATROL HAVE A TIMING BELT OR CHAIN 4CYL 3 LT THANKS
This was posted under musical instruments with" TC Electronic Finalizer Express..." as the header. It belongs under Automotives or Cars. Hope this helps.
Oct 31, 2010 | TC Electronic Finalizer EXpress...
Hi my tc finalizer (upgradet to fin plus) recently stays switches off. the problem is always after switching on the complete environment. it needs a while that th tc ´s display is lighted. these...
First try the self test function.
If it will not respond I suspect the unit has a power supply problem and will require servicing. This is an internal thing and not DIY unless you have electronic experience.
Sep 06, 2010 | TC Electronic Finalizer EXpress...
TC Electronic D-Two Power unit locked up display
I don't know if this will help. Have you looked for a battery on the circuit board that backs up the memory? A lot of synths use them and when they go the unit quits functioning. Some will start right up again once the battery is replaced others require a system update through a download. Anyways I always recommend contacting the company in question. They should be able to tell you simply whether it needs servicing or not:http://tcsupport.custhelp.com/cgi-bin/tcsupport.cfg/php/enduser/ask.php
Jul 14, 2010 | TC Electronic Finalizer EXpress...
TC Electronic Nova Repeater Pedal Guitar Logo
265 people viewed this question
Top TC Electronic Music Experts
bigdawg7299
Tom Chichester
Seanzilla
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
