Question about Acer AL1916W 19" LCD Monitor
No signal everythings plugged in and turned on still says no signal in goes to standby mode.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
1. change the VGA cable and test.
2. Plug to another PC or notebook and test.
if still no signal, it might be the display board inside the LCD is faulty.
You need to get a certified technician to fix it.
If cost is higher than 1/3 of a new 18.5" new :LCD monitor; I think you need to think of purchasing
a new LCD already. As new LCD will cover you with 3 years warranty.
take care.
Posted on Jan 03, 2011
SOURCE:
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
When you push the power but it trys to come on but goes to standby mode
You need to have a source on and sending a signal to the tv, or it goes to standby. Some units you turn the tv on and need to select the input to which you have a signal going to.
Oct 02, 2010 | Emerson Televison & Video
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
May 03, 2010 | Westinghouse L2046NV Monitor
WILL NOT LIGHT UP-COMPLETELY DEAD
Hope this helps! :)
May 03, 2010 | E-Machines eMachines Monitor E15T4
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Turn off tv power
First your tv will always go into "Standby" when it receives a "Power off" signal. Made that way. Second, It is never a good thing to have your tv power plugged into a "Switched" outlet on a Cable ot Sat box or some other Component. The tv should be always be plugged into the wall outlet or through a very good surge protector.
Jul 12, 2009 | Televison & Video
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Acer AL1916W 19" LCD Monitor Logo
122 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
