Question about Vacuums
Piccolo bagless 2000w cyclonic vacuum red light appeared
  • 72 Answers
SOURCE: Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Posted on Oct 20, 2007
  • 389 Answers
SOURCE: I have a Dyson DC17 Animal Bagless Upright
OK. Lost suction almost always means blockage. You need to check all the pipework, the hose and any bits you can remove at the base of the machine - if I remember right, the DC17 has a sort of U shaped bend at the bottom of the handle that you can remove - also turn it over and inspect the clear flexible plastic tube (if it's not blocked, it can get damaged and leak). As for filters, you do of course need regularly to wash the filter that's above the cannister (wash both the blue sponge and the yellow carrier) and be sure they are dried gently for at least 12 hours before putting them back.  If you need new filters, any vacuum service shop should be able to supply them. I hope this helps. I value your feedback so please remember to rate my response.  Good luck!
Posted on Feb 25, 2009
SOURCE: Saeco 00095 Piccolo Canister Steam Vacuum
Where do I go to get tech.spec's on 00095 Piccolo and where to buy one online?
Posted on Nov 18, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
Vac Belts
  • 701 Answers
SOURCE: my dyson vacuum appears to still have suction but it doesnt
That means that the belt is stretched or worn. This causes the roller brush to not be able to turn the way its supposed to against the resistance of the carpet and therefore won't pick up well. You need to replace the belt. Here are the belts you need:
Dyson DC14 Belts
Posted on Feb 07, 2010
How am I suppose to emty The uh70060I feel that I am not getting all the dirt out. Can the red top be removed?
Hi! It is not recommended you disassemble the red cyclonic filter. You may use your upholstery brush or something similar to brush off the cyclonic filter. You may also wipe it down with a damp cloth. Do not rinse or submerge the cyclonic filter in water. Hope this helps!
Jul 09, 2014 | Hoover UH70060 Bagless Upright Cyclonic...
There is no suction on my vaccum, hoses appear not to be blocked
have you checked your permanent filter. is that plugged? Have you taken the small solid plastic passage off the side of the machine and checked for a plug there?
Did you by chance rinse your cyclone with water at some point? You can disassemble the cyclone and clean that. google has some videos on cleaning your cyclone. just google clean dc07 cyclone and you'll get several
Sep 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum runs but does not pick up dirt
Have you cleaned the washable filter. Perhaps your cyclones are clogged. you can clean the cyclones yourself. check out this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Flashing charging lights when on charger.
smething internal is burnt out possible bad battery.
Nov 29, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Vax v-60P turboforce pet bagless upright 2000w
hi phoned vax today.. they said there's definately NOT a problem with that particuliar model. I now have to send the 2nd cleaner back to them to repair...If this problem occurs again they will replace it with another model!!!
so watch this space!!!
I think having two vacs blow up is too much of a coincidence!
I have been using vacs for nearly 40 years & I've never had this happen before!
If Anyone comes across the same problem I would appreciate you letting me know.
Thanks for your time
Liz
Jun 09, 2008 | VAX Appliances Vax X5 Bagless Upright...
Eureka Whirl wind electornic bagless cyclonic system
Not sure if yours is a 4499B, couldn't find in the parts list any red light. But most times when there is a red light it is telling you that if it had a bag, it would be full, but in your case, maybe you have a cogged filter and inlet down by the brush roll.
Nov 27, 2007 | Eureka Whirlwind 4499B Bagless Upright...
Vacuums Logo
491 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
