I have a HP 8250 printer....wont print. I get the following messaage. INK SYSTEM FAILURE The ink system has failed and can no longer print. Refer to printer documentation. ERROR Oxc18a0201. Turn printer off then on. What to do ????
  • 613 Answers
Best simple fix is to take out entire program thru Control panel>add/remove and restart the computer and then reinstall it. Should take only 15 minutes.
Posted on Jan 03, 2011
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Ink system failure and can no longer print. refer toprinter documentation. error 0xc18a0101 turn printer off then on.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a free step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 24, 2009 | HP Photosmart 8250 InkJet Printer
The ink system has failed and can no longer print. Refer to your documentation. ERROR 0xc18a0406
HP support has the following recommendations:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=443024&docname=c01458034#reset_product
Dec 06, 2009 | HP Photosmart 8250 InkJet Printer
Ink system failure
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Dec 11, 2008 | HP Photosmart 8250 InkJet Printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
Photosmart 8250 printing computer codes
my printer photosmart 8250 is printing does not print it says ink system failure when i try to replace it the yellow ink jet so please please help i'm in third world country my email address is abrbw@yahoo.com please help again
Jul 17, 2008 | HP Photosmart 8250 InkJet Printer
Photoprinter 8250 error oxc18aoloa
I had the ink system failure on my HP Photosmart 8250. Here is how I fixed it...no promises that this is the problem with all of these failures:
Start by opening the printer up to expose the ink pump on the left hand side. Remove the left side dark grey trim, then take out the screws to remove the left side panel. You will have to use some force. I slightly damaged the plastic because I was impatient - be careful if you want it to still look nice.
The ink pump is in the bottom left. In my printer, a large gear had fallen off of the pump and was laying in the bottom of the case. I removed the belt drive to the ink pump, then removed the large pulley that the belt went around. This lets you put the gear back on the ink pump. Use a dot of glue on the shaft if you want. Now, replace the large pulley and the belt.
This fixes the problem, but does not clear the error code. To do this, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us Click on the link for your operating system, then click on, download, and use the link that says "recomend update to fix long power-on cycle and ink system failures" This clears the ink failure trouble code and lets the printer re-initialize the ink system.
Oh...put the plastic back on if you want to. Otherwise, you can leave it off and watch all the bits and pieces move around in the printer.
Again - this is how I fixed mine. No promises that this is what has caused the others to fail. The HP website says not to use the patch if you can see ink coming out of the printer. This sounds like good advice to me as the initialization process runs the ink pump for about a minute.
Mar 05, 2008 | HP Photosmart 8250 InkJet Printer
Printer will not print
Well you can follow these steps provided by HP for that very problem. http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=nl&cc=be&dlc=nl&docname=c00719450 hope that was helpful, lemme know how it works out:) regards, babb
May 01, 2007 | HP - HP Photosmart 8250 printer
222 people viewed this question
k24674
jasbo
jasbo
