Question about Refrigerators
My icemaker stopped working and it's leaking inside.what could be the problem?
  • 472 Answers
Check the fill tube to the ice maker and make sure it is not froze up or obstructed...when the ice maker calls for water there is a tube that comes into the ice maker and often will have residual water that can eventually freeze and make a mess the next cycle and so forth... also make sure the ice maker it self has not developed a hole in it...this is metal and water we are dealing with very possible to happen over time and start leaking through front control etc......good luck to you hope you get it fixed........please vote....
Posted on Jan 03, 2011
Why does water drop before ice is made?
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Mar 28, 2016 | Refrigerators
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
May 05, 2015 | Maytag Refrigerators
How to fix a kenmore ice maker leaking water
Feb 20, 2015 | Kenmore Refrigerators
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water is leaking from inside of the refrigerator and we are constantly wiping off water from the floor. The icemaker isn't working.
I don't mean to sound sarcastic here but have you lifted the icemaker arm to see if the leaks stops? If it does the icemaker water inlet thru tube from the back of the unit is somehow wither not alightned with the icemaker inlet or the icemaker itself is letting water go though it.
Having said that if your unit is all froze up in the back of your freeze and the fan can no longer circulate air properly that too can cause bot the icemaker to stop working and a leak if the upper cabinet drain is iced over.
You can make sure it is not an icing / "not defrosting" problem by unplugging the unit and placing a fan blowing into the freezer section for at least 2 hours. Mind you this will only add to your water messes but it is a must do so have the mop and rags ready when you do this. Once you have done the fan routine plug it back in and see if after 8 or more hours that the leaks stop and the icemaker functions.
If after all of this it does funtion normally then you unit is not defrosting and will need to have the defrosting system checked out. NOTE after a few days (3 - 6) it most likely will start freezing up again if there is in fact a defrost problem and it will repeat the same antics in the past. Hope this was helpful.
Jan 18, 2010 | Refrigerators
Ice maker leaks water, when you lift the bar that turns ice maker off it stops. haven't taken front cover off yet. is there a valve or seal in there.
I would suggest replacing the complete icemaker . Some icemakers , due to the coating , bubble inside or the coating wears off . When the coating wears , water will "eat" thru the pot metal aluminum . Also some have sensors that are not sealed well , and water will leak thru the seal . The quickest and most reliable way , is to replace the icemaker ( 1 year warranty on new icemaker ).
Sep 09, 2009 | Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
