Question about Haier HLP23E Top Load Washer
IN haier hlp23e, how to rotate drain pipe inside the machine from right to left.
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: haier washer machine HLP23E makes a noise
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Posted on Jan 04, 2010
Haier HLP23E - When I press start, the water flows in and out at the same time.
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Dec 13, 2014 | Haier HLP23E Top Load Washer
WATER GOES INTO MY WASHER AND RUNS RIGHT OUT
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Nov 18, 2012 | Haier HLP23E Top Load Washer
Haier hlp23e washer makes a rattling sound during spin that almost sounds like coins being slapped by an impeller. How do I fix?
Here's what I did that seemed to fix it. You know that plastic attachment you screwed onto the bottom? I'm pretty sure the noise is made by the bottom of the machine spinning against it. I thought the noise sounded sort of plastic-y, so I removed the bottom and sure enough, there were circular scratch marks on it. I haven't heard that annoying rattling yet.
May 05, 2012 | Haier HLP23E Top Load Washer
Hi, I bought a Haier 8.8-lb. 1.6 cu. ft. Capacity Portable Top-Load Clothes Washer from drugstore.com two week ago. When water goes into the machine, I found the water came out from drain tube at the same...
Have you got the drain pile positioned higher than the top of the machine. If the outlet of the pipe is lower than the water level, the water will just run out. If this is not the problem then don't even try adjust or open the unit. Take it back to the dealer or you will void your warranty and it is not worth it. Let the dealer worry about it.
Feb 21, 2011 | Haier HLP23E Top Load Washer
Haier HLP23E Top Load Washer Logo
60 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
