Question about GE JVM1190 Microwave Oven
Should microwave 1.58 kw be on sperate circuit
    Novelist:
  • 128 Answers
The answer is yes. All appliances in your kitchen should have a dedicated breaker.
Microwaves draw a high number of "amps" when starting. Most new microwaves have a 20amp fuse internally, yet the household circuit breaker should be 15 amps.
I'd suggest hiring a licensed electrician to be sure the hookup is to code for your area.
Posted on Jan 03, 2011
How to replace door handle
open door
lift up seal of door to expose srews then remove
sperate seal and inside door glass
that exposes screws for the handel remove and replace
Jun 30, 2012 | GE JVM1330BW/WW Microwave Oven
My Samsung microwave model SMH7187STG 1.65 KW is showing error message E-13
E-13 T1 Max time error (oven did not preheat properly). This can be due to improper power line voltage, a failing thermistor, a bad damper seal, or possibly a faulty control circuit board. I would first verify proper operation with the manual, then if it still acts up and if it's in warranty, I would contact Samsung support. But if it's out of warranty and works okay otherwise, it may not be serious enough to worry about.
Hope this helps.
Oct 31, 2010 | Samsung Microwave Ovens
Oven runs does not heat GE EMO3000
the microwave runs does not heat the model is jvm 1660BB003 KW:1.58
Dec 05, 2009 | GE Microwave Ovens
Have an older gaffers and sattler stove with microwave built into top. do you know what wattage the microwave is. tahnk you. Paulamrella@verizon.net
Check the manufacturer plate label on your microwave. It may be written like this- KW usually beside the Manufacturer model number.
You could also do a little calculation by checking the voltage and ampage readings. multiply them is going to give you wattage.
Jul 24, 2008 | Microwave Ovens
Difference in KW
.25Kw or 250 watts of cooking power.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | Samsung MW5592W Microwave Oven
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
Jan 09, 2008 | GE JVM1190 Microwave Oven
GE JVM1190 Microwave Oven Logo
204 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
