Question about Sony Reader Pocket PRS-300
Hi! i have a problem with my prs 300 sony reader. my reader opens the page of a book that i am reading but when i open another book the page is stuck with the old page that i am reading. sometimes the page says invalid page. i am really disappointed. i already have 182 books already in my reader. btw, i live in the philippines and the reader was just bought for me from canada. i hope you can answer my query. thanks!
    Master:
  • Sony Master
  • 198 Answers
Depending on what the file type is you can always try another application to open up the book for example if it is a pdf format you can always try using adobe reader. However, I believe the issue here is that there is a page that might have been corrupted or unviewable depending on the situation you may want to consult whoever you got the book from in case you had purchased this book to see if you can maybe get another copy.
Posted on Jul 15, 2017
ani24das
  • 89 Answers
SOURCE: my sony prs 300 seems to be working fine except it
Does this issue occur with all the books??? If the issueis with only one book, delete the book from the Library as well as from the Reader. Then, download it again. If the issue is with all the books, perform a hard reset and then download the bvooks and then transfer them to the Reader, That should resolve the issue.
Posted on Jan 26, 2010
SOURCE: Sony PRS 300 reader STUCK, FROZEN, 184 books on it!
did you use the usb to recharge it? maybe you've connected the usb to the ebook but it didn't recharge. The battery will drain if you just connect it to the computer but didn't recharge (bad contact between the book and usb, mine does that). try to recharge it, make sure the light beside the on/off button is on (red), let it sit for few hours that it should be fine
Posted on Aug 12, 2010
  • 370 Answers
SOURCE: my sony reader prs-300 is
If your phone freezes, hangs up unexpectedly, vibrates continuously or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Posted on Aug 13, 2010
SOURCE: Why are my books are
Try reformatting the memory, its in settings, advanced settings, then format internal memory, worked for me. will erase any books on the reader already though.
Posted on Dec 25, 2010
SOURCE: Can I delete a book off of the Sony ereader PRS
how do i delete the books that come with the ereaderprs 300
Posted on Apr 02, 2011
How do i delete books
There are 2 ways. First being the easiest, since it can delete multiple books at one time. USB connect the PRS-300 to the PC. (It will read as a hard drive.) Go to the "database" folder, then to the "media" folder, then into the "books" folder. All your eBooks should show there, and you can choose which ones you want to delete and delete them all at once.
The second way only deletes 1 book at a time. Choose the book, then choose "Continue Reading" to open the book's menu page ("Options") on the reader. On the "Options" menu, choose "Utilities". When the "Utilities" menu comes up, press 2 for "Delete Book".
Aug 29, 2011 | Sony Reader Pocket PRS-300
My sony e-reader won't sync with my computer. It will try, but it gets stuck on processing.
Hi!
Probably a corrupted book that will not transfer, I recommend you to check book by book to see if ther is one that is not displaying on the Sony Software, also you can disable sync, here's a link how to do it:
http://digialreader.freeforums.org/how-to-disable-sync-t20.html
GoodLuck!
eBookBoy
Jul 16, 2011 | Sony Reader Pocket PRS-300
The device has been working fine for well over a year now but recently it seems to freak out in the middle of a book, get confused and go back to the home menu. Now, more worringly I now cannot start...
Hi!
Probably sometinng got corrupted on the book, you can try a soft reset to see if the issue is fixed, if not you will need to do a hard reset, this will set the reader to factory settings and remove all data:
Note: Make sure the reader is at least half charged.
To Soft Reset:
1. With the reader disconnected from the computer, hit the reset at the bottom of the reader for 3 secons
2. Slide the power switch, the screen will blink and will show "Opening Book". Allow the reader to load and see if the problem still persist
To Hard Reset:
1. Hit the reset button at the bottom of the reader for 3 secons
2. While the reader shows "Opening Book" press and hold at the same time the number zero "0" and the down arrow on the directional buttons until "Reset All" appears
3. The reader wil laskyou to press the number 5 to proceed
4 Reader will go off, now you can turn it on and allow it to load this time.
GoodLuck!
eBookBoy
Jul 11, 2011 | Sony Reader Pocket PRS-300
I am unable to use my reader (300). It marks error 2001
Hi elaterza,
Is this an error coming up on the Reader Software or the Reader itself?
If is from the reader you may try to reset it:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening Book", allow the reader to load
Check if the issue is resolved
GoodLuck!
eBookBoy
Jul 09, 2011 | Sony Reader Pocket PRS-300
PRS-300 All the books I import into the library will not sync into the reader. Some books that I purchased are coming up the the reader won't support them even though they are epub files.
Hi!
You can try to delete the books and redownload them again, probably something got corrupted.
To Redownload books:
1. Open the Reader Library
2. Sign In to you account
3. Click "My Account" link at the top of the page
4. Scroll down and click the link that says "Redownload purchased Items"
5. Click the download button
6. Transfer your books again
GoodLuck!
eBookBoy
Jul 07, 2011 | Sony Reader Pocket PRS-300
My sony prs 350 ereader screen froze when i was reading my book when i try to turn it off the light turns red and it is fully charged
Hi!
If the Reader is frozen, you can try the following:
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
eBookBoy
May 06, 2011 | Sony E-reader Portable E-book MP3 Player
How do I download my new ebook onto my sony ereader? Not the PRS-600 but the PRS-300.
first, download and install the Reader Library Software in the Compouter. download the software frm http://ebookstore.sony.com/download/ . Then, purchase and download the books to the library. Connect the Reader to the Computer. The Reader will be listed at the left pane of the software window. Now, open the library and then drag and drop the book to the Reader.
Dec 28, 2009 | Sony Reader Touch PRS-600
My sony prs 300 seems to be working fine except it
Dec 05, 2009 | Sony Reader Pocket PRS-300
Sony Reader Pocket PRS-300 Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
