Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung rf266 lower icemaker diagram rf266 lower icemaker
How do I remove flapper bar left French door Samsung RF266 fridge to replace gasket? Thank you
here is the manual on removing the doors. This will show you how to remove the door, then replace. http://downloadcenter.samsung.com/content/UM/200909/20090913021004593/DA68-01812H_RF266_RF263.pdf
Sep 20, 2016 | Samsung Refrigerators
THe filter light will not go out on our Samsung RF266.
If memory serves, you put your finger on & hold the filter warning indicator for 3+ seconds and that will reset it after the filter is replaced. I've temporarily misplaced my owner's manual to confirm for certain.
Sep 08, 2014 | Samsung Refrigerators
My icemaker in lower freezer came loose how do i fix samsung
There should be two screws holding the ice maker to the top of the freezer compartment. If those fell out, it would explain your problem.
Mar 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
We changed the filter on the icemaker but tye light is still on asking for a filter. now what makes the light go out?
The light stays on, actually. RF265/6/7 models have a blue LED water filter indicator that remains lit in normal mode. After about 5 months [on a 300 gal. filter] the LED indicator will turn pink and then red at about 6 months. Derived from RF266 users manual, hope this helps.
Oct 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
Freezer problem
Pull out the freezer door & drawer. Check in the back, up high and you'll see a cover for your freezer evaporation controller (fan). There's a cute, quiet little fan up there that circulates the cold air when the door closes; it has probably failed on you. Without it, the icemaker quits/faults out, you get a lot of frost and generally a poor attitude towards the company; which I can't blame you. Luckily, we had the warranty AND the right tech showed up after six tries. Thought I'd get a new one after two tries but they snaked their way out of that and I have a worked freezer again.
Jul 12, 2010 | Samsung RF265AA Bottom Freezer French Door...
Water not going to icemaker. Replaced water solinoid valve still have same problem. Also looking for complete wiring diagram.
make sure that freezzer is 15deg or lower . 5 deg is best . ice maker will not call for water unless its that cold. wire diagram / need to know brand and model . it may not be abilb in the service . without getting factory help . **** ..
Feb 23, 2010 | Refrigerators
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator model RS2577SW. Can't lower
Try turning off the unit. Then leave both doors open for 48hrs to defrost it 100%. Now try moving the icemaker bar as there may be ice in side freezing it solid. If not I'd say it's time for a new ice maker Cheers
Mar 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Feb 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
1,045 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
