Question about LG Washing Machines
We can not find instructions in our owners manual as to where the bleach is to be filled in our front load LG WD11020D washer? Can you tell us where to fill it and how much to use? Thanks
    President:
  • 1,796 Answers
Hi!!
You can use washing detergent w/bleach on the main wash detergent dispenser, this has to be approved for front washer use and should have a label stating so. About the amount to be used, follow the indications on the package.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Jan 03, 2011
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    I need a manual for my LG WD11020D front load washing machine
    go here http://ebookpin.com/electronics/lg-washing-machine-owner-manual-wd13020d-wd12020d-wd11020d-pdf but after opening it do NOT try to scroll - it will crash. Instead go to menu and SAVE AS and then reopen from your local drive
    Nov 02, 2010 | Kitchen Ranges
    How much bleach do I put into the cleaner cycle?
    You should have this information in your owner's manual. However, most front load washers have a small designated area in the dispenser container that only allows a certain amount of bleach (usually very small amount). But, check your owner's manual for specific amount.
    Feb 20, 2010 | Kenmore HE2 Plus Front Load Washer
    Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
    The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
    Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    LG Front Loading Washing Machine
    Bleach goes in on a calculated time.Yes some one could have reversed lines.Actually the harness i believe.
    Jun 10, 2008 | Frigidaire ATF6000ES Front Load Washer
    Lg washer
    make sure your machine is lavel and just a little higher in the front about 1/16 in and do not fill all the way to line just under line
    Oct 22, 2007 | LG WM-2277HW Front Load Washer
    LG WM2233H Washer
    Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
    Oct 01, 2007 | LG WM-2277HW Front Load Washer
    LG TROMM WM2487 Bleach not getting fully removed after cycle
    Keeping in mind that the bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water.  Is your cold water valve screen plugged causing your washer to rinse poorley?  Are you using the HE detergent?  If not maybe the washer is sudsing up to much and haveing a hard time rinsing all the suds and bleach out.
    Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up?  Also when it is full and agitating is there suds in the washer?
    Last suggestion is if the drain is hose is alot higher than the top of the washer it might have a hard time draining out all of the bleach water before the next load
    Aug 26, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Washing Machines Logo
    186 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
