Question about Solis Maestro Electric Burr Grinder
Dissasembled for cleaning. after reassembly only fine grind is possible. What did I do wrong? What is correct system for reassembly?
How come my troy snowblower stalls when I move the choke switch from choke to run ?
Most likely issue is dirty carburetor. Dissasemble and clean with carb cleaner or sea foam (let parts soak in it, if possible), reassemble. Could also be head gasket, but less likely.
Feb 17, 2015 | Troy Garden
Why is my navigator cleaning in reverse?
Check the positioning of the reverse switch.
Apr 30, 2014 | Hayward Navigator Pool Cleaner
How do I clean the bean grinder in a seaco royal profesionla machine?
These instructions come directly from the service manual. Notice the mention of a qualified technician. If you do this on your own be careful. If you don't follow the instructions correctly or you break something you've will have no one to blame but yourself.
-Clean the coffee beans container periodically; this operation should be accomplished by a qualified technician! Unplug the machine. Empty the coffee container and unloose the two fastening screws. Now, the container can be removed and cleaned.
-Carefully pull the adjustment lever upwards, previously writing the set grinding degree.
-Turn the adjustment ring counterclockwise, until the blue marks coincide.
-Now, it is possible to remove the grinding ring from the machine, slightly pulling it upwards.
-With the aid of a brush or a narrow vacuum hose, clean both the gear box and the grind ring support. Make sure the position of the grind ring does not shift. To reassemble the coffee grinder, carry out the reverse sequence, making sure the adjustment ring has not been shifted during cleaning. If that is the case, turn it until the blue mark coincide with one of the three notches. Assemble the grind ring support and make sure the blue marks coincide.
-Turn the adjustment ring clockwise, to make the red marks coincide.
-Fit the adjustment lever on the ring, until it coincides with the previously set grinding degree.
Nov 28, 2010 | Saeco Royal Professional Espresso Machine
HI, I HAVE A HONDA CB125 TDE SUPERDREAM 87, BIG END LOOSE
I think honda only sells the complete crank as you have been told.
An expert engine machinist may be able to dissasemble the crank rebuild the journals, grind, source oversize\undersize bearings, refit bearings, reassemble and balance, but the time and cost would be more than a crank.
You may chase a second hand one from a bike breaker, personally I would try to find another motor, as if the big end has gone, there will be wear in other areas of the motor, like the cam bearings which also are not replaceable. It must have had an oil problem..
Jun 19, 2010 | 2001 Honda CB 125 T
Winchester 1897 missing parts
try gunparts.com or firingline.com
Aug 12, 2009 | Rock & Ice Climbing
I have a 2001 Buick Lesabre. the ABS light came
you can disconnect the battery for 5 minutes.
Jun 25, 2009 | 2001 Buick LeSabre
Embarassing but...
No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
Jan 02, 2009 | Solis Maestro Electric Burr Grinder
Grind
Love your 'handle'!
I'm thinking that there is something in the burr in the unit. Empty the unit and remove the burr. Usually, this is done with a counterclockwise turn. Note how hard it may be to turn...you'll have to reverse this when you put it together. Now, clean out any coffee debris you find. Then, turn the unit over and tap it on a firm surface covered with newspaper. Reassemble and return to service.
Nov 03, 2007 | Grindmaster 810 Electric Burr Grinder
Solis Maestro Electric Burr Grinder Logo
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
isaac johny
isaac johny
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
