Question about Samsung V20 XVC 2400 Notebook
Screen fault on samsung v20
Hi The screen does not light up .I have changed the Sic350d board but still no screen .I can see the display with a light shining on it
    Genius:
  • 1,019 Answers
screen tube or inverter board faulty.
change the inverter board, then replace the CFL tube.
Or replace the whole tft screen.
Mike @ Compurepair.
Posted on Jul 31, 2008
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
How do I fix a Samsung TV #pn58c8000yf that has sound but no pix?
Contact the authorized service center. It will be better in case of Plasma displays. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 02, 2015 | Samsung 3D Plasma TV PN58C8000YFXZA...
Samsung sens v20 laptop power on but no display
Any sound? Does the HDD led blink during start-up? Can you hook it up to a external display? If so, what is on the screen?
Nov 27, 2013 | Samsung V20 XVC 2400 Notebook
Hi all i have an Samsung V20 from an customer to repair - i have to dissasemble to correct blank screen bur could not part the top kayboard side from the bottom all screws are taken out but on both sides...
I checked previous solutions provided here for this fault and found the following
http://www.fixya.com/support/t3821432-start_samsung_v20_up_all_get_blank
Please read all the way through first.
Apr 03, 2011 | Samsung V20 XVC 2400 Notebook
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
Hi, i have a samsung v20 laptop.2 questions...
I have a Samsung V20 for many years and I know it doesn't support a wireless connection built in. But if you connect a USB like myself you can have access to the internet wirelessly. The flikering on the screen are you sure you haven't got a screen saver switched on, you may have it set to a clear black screen and like you say have to tap the keyboard and it comes back to life. It may also have hibernation switched on which will automatically turn off the screen have so many minutes you can change all these setting by right clicking on the desktop and selecting properties and under the screen saver tab there will be a power btton you should see hibernation and other tabs across the top these can be altered to whatever you want.
Hope this of use.
Dec 05, 2008 | Samsung V20 XVC 2400 Notebook
The plug on the screen ribbon cable which connects to the motherboard has dry solder joints. Closing the screen and typing hard on the keyboard can break these joints very easily. All you need to do is re-solder the joints. This is a very delicate job and requires a lot of patience.
Nov 29, 2008 | Samsung V20 XVC 2400 Notebook
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
Samsung v20
You should install the driver enclosed in to your laptop/pc provided by the vendor. however you have no CD/DVD disc utilities u can download the driver here: http://www.samsung.com/hk_en/support/download/supportDownMain.do
Please say something before your rate. thanks!
Jan 24, 2008 | Samsung V20 XVC 2400 Notebook
Samsung V20 XVC 2400 Notebook Logo
115 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
