Question about Saeco Royal Cappuccino Espresso Machine
The beans will grind but there is a bad clicking/knocking noise and coffee wont come out, water heats etc no error message
  • 1,089 Answers
Hi
The dreaded clicking noise is usually the brew drive gears are broken. Usually caused by too much coffee in the brew unit that it can't compress ( 2 scoops of coffee). If you have ever done that, its broken but can be fixed.
Posted on Jan 03, 2011
Delonghi Magnifica EAM3400 When using pre-ground coffee I get the message; Grind too fine, turn steam knob. I do, but nothing changes. I pull out the diffuser, clean out the coffee, try again with beans -...
That is the reason the old owners gave it to you . You have to change the circuit board for it and it is as expensive as a new unit plus the labour and shipping .
Oct 30, 2013 | DeLonghi Coffee Makers & Espresso Machines
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
Its telling me that coffee beans are empty...but they are not..it makes grinding noise but the message keeps popping up beans are empty
You have one of 2 problems either the grinds chute to the brew unit is blocked, or the grind is too fine.
Sep 18, 2010 | Gaggia Syncrony Compact Coffee...
When machine grinds coffee it makes winding noise but does not grind coffee, hence you get water
This is a desgin flaw of this machine. Hapens when you use the machine over a long continous period. The water damp makes the grinder wet a it cakes up. The spring is supposed to remove the debris but does not work well. Remove beans form bean tray. Remove the bean tray (1 screw and pull the knob off). Use a vacuum cleaner to **** out the wet bean grind. Dry the wet damp area and use a tooth pick to remove the bean grind (especially around the scute). Let dry and assemble, Good luck!
Aug 09, 2010 | Krups Small Appliances Espresso Machine
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
314 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
