Hq 1054 fe 1.5 - Washing Machines
Codes reading 1054 and 0600
1054 = is an error in your oxygen sensor (probally the problem and an easy fix)
P0600 = Serial Communication Link Malfunction (mor than likely related to the first)
May 20, 2012 | Volvo S70 Cars & Trucks
I can't chat on face book..
ја могу само на опера бровсер да да видим основне графице а на друге бровсере немогу а сада на опера немогу да видим ко је све на чату и то ми се догађа од ових недељу дана и све исто .........................................................СКО ЈЕ ТО НЕШТО ДО ВАШ МОЛИВАШ ПОПРАВИТЕ ТО АКО ЈЕ ДО МЕНЕ ПОШАЉИТЕ Е МАИЛ СА ПОРУКОМ ШТА ТРЕБА ДА УРАДИМ НА ЕМАИЛ АНДРЕСУ -анђео_беч@хотмаил.com
Jun 21, 2011 | Facebook Social Network
What is serial number of soundforge 7.0
Try these versions Serials:
Sound forge 7.0
HQ-9YJQ0V-0F8VGX-7GGQCM
Sound Forge 7.0a Retail
HQ-1PS2Y1-VHKZ6M-GZGENX
Sound Forge 7.0b build 301
HQ-8JQ9S3-60Q9V0-3J90E1
Sound Forge 7.0b b301
HQ-D11Z59-T6LMRY-TN0QPL
HQ-6HRZFM-R9WLJD-4WHR2V
HQ-4S8T0N-7T0HV5-QHCJL4
HQ-52L3KY-9885MG-Z9E6J5
HQ-3RCGXN-YP6TQ9-LWTWYK
Jul 09, 2010 | Computers & Internet
MANUAL
we can`t read your massage ,re write it.
Apr 30, 2010 | Office Equipment & Supplies
Support for error codes
14, NP112, PC3 Код ошибки Описание E0 Heat lamp E2 Scanner
Canon 210, 300 Код ошибки Описание E0 Heat problem E1 Sorter E2 Scanner E4 Drum drive E5 Lens drive E6 Exposure lamp E7 Mirror sensors
Canon 25, 250, 270, 350 Код ошибки Описание E0 Thermistor/thermoswitch or heat lamps E1 Sorter E2 Scanner home E3 Scanner return E4 Right front door/main motor E5 Lens home E6 Lamp regulator E8 Counter wire
Canon 400, 500 Код ошибки Описание E0 Fuser E1 Sorter E2 Scan home E3 Scan E4 Clock pulse or open RF door E5 Lens position E6 Exposure lamp, fuse 2 E8 Counter
Canon 5L, 5ll, 5Lll, 3ll, 2L, PC-1, PC-2, PC-5 Код ошибки Описание E0 Heater problem E1 The heater film has gone off center. Turn machine off & on, make sure it's level etc. E2 Scan problme E6 Exposure lamp or exposure lamp sensor
Canon NP1215 Код ошибки Описание E000 Low temperature, thermoswitch, thermistor or AC driver E001 High temperature, thermistor, AC driver E030 Counter E202 Scan not returning home. Scan not leaving home E221 Lamp regulator board E400 Document feeder problem E500 Sorter problem
Canon 150 Код ошибки Описание E0 Thermistor, thermal switch, heat E1 Sorter, scanner home E2 Motor, clock pulse E3 Scan problem E4 Lens home E5 Lamp regulator/document sensor E6 Motor control E7 Total counter E8 Lamp regulator E9 Copyboard drive motor/board ED Motor control PCB EE DC controller on motor E001 High fuser temperature. Shorter fuser thermistor E030 Total counter disconnected or open E202 Scan problem E210 Lens problem E221 DC power supply, lamp regulator board or main board E400 Document feeder board problem E500 Sorter board problem E000 Low fuser temperature
Canon 1500 Код ошибки Описание E001 High fuser temperature. Shorter fuser thermistor E030 Total counter disconnected or open E202 Scan problem
Jan 19, 2010 | Office Equipment & Supplies
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
