Question about Yamaha RX-V730 Receiver
What output jack should a wireless headphone system be connected to for use by a hearing impaired person, while still allowing sound fron the external speakers for others in the room to listen to? The headphone being considered has its' own independent volume control. The Receiver is a Yamaha RX-V730.
  • 583 Answers
The REC OUT jacks on the back are usually the best as they are not affected by the system volume. You'll need an RCA L and R Male to Headphone (1/4" female) adapter (available at Radio Shack and online sellers).
Posted on Jan 03, 2011
    Sergeant:
    Champion:
  • 342 Answers
The Tape out or record out is the port i would use if it has a Red and White stereo cable to the headset.
    Scholar:
  • 85 Answers
I would connect the headphones to tape out. That output always matches the current source. The only setting adjustment that would need to be made would be to set that output as a fixed volume in the reciever settings so that its always at max output and the volume adjustment can be made at the headphones themselves.
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Can I watch a DVD and use the WH-930 headphones to hear it better?
Most DVD's have line-level outputs which will NOT drive headphones. You need to run the audio line outputs, which are usually RCA jacks to jacks on an amplifier and then plug the headphomes into that. An inexpensive source for an amplifier is OFTEN at thrift shops. Run the pair of cables into jacks that would likely be labeled TAPE INPUT for example. FInd one that does have a headphone output jack on the front.
Oct 23, 2011 | Sylvania SYL-WH930GB Wireless Headphones
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Jul 09, 2009 | Sennheiser RS 120 Consumer Headphones
Headphone Jack
Unfortunately these units are designed to output to either the speakers or the headphones. There are devices available on the market that will take the output from the tape-out jacks and transmit it to a wireless headphone. I would suggest that you investigate this. That would also eliminate any wires stretching from the equipment.
Search the web for "assistive listening" devices.
Dan
May 13, 2008 | Onkyo TX-SR605 Receiver
Philips model#HTS3544/37
According to the manual, there is not a dedicated ear-phone jack on the unit. However, it does have an analog audio-out jack in the back which could be connected to a y-cable adapter, and then connected to headphones with a built-in volume control.
Dec 31, 2007 | Audio Players & Recorders
Yamaha RX-V730 Receiver Logo
219 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
