Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Dishwasher won't drain. runs through normal cycles, and then just stops still full of water on the bottom. I have taken it apart and can't see any obstructions.
    Sergeant:
    Champion:
  • 342 Answers
Is there a clog in the hose somewhere because when ours clogged it would not drain it just kept circulating water all over the clean dishes and it was gross
Posted on Jan 03, 2011
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
My Smsung dishwasher always has suds in the bottom after cycle has completed
Couple of questions?
1. do you have a water softener?
2. what type of detergent are you using and how much?
3. is the detergent HE rated?
To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
Sep 17, 2012 | Samsung DMT300RFS Builtin Dishwasher
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
When I tried to turn off the dishwasher, it accidentally started the cycle again. I pushed the off button to stop it, but the bottom is full of water. How do I drain the stop and stop the cycle?
It would help if you provide the make and full model number of the dishwasher.
Normally you would press the drain/ cancel button if you have one.
if not it should most likely drain when you start the next cycle.
Nov 24, 2010 | Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Fisher paykel dishwasher dd601I runs complete normal cycle and finishes normally. 2-3 sec. after completion the washer motor srarts to run and the f1 fault (flood sw. activated) is dislayed. When the power...
Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
Jan 20, 2010 | Dishwashers
Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Sep 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
