Question about Car Audio & Video
Soundstream Reference Class A 6.0 car amplifier has entire bank of 18 low ESR capacitors blown along with 3 adjacent small resistors in the power supply section. What may have caused this and should I check any other components before replacing these parts?
  • Khan Powell Jan 03, 2011
    Looking for someone familiar with the old Soundstream class A amplifiers please.
  • Khan Powell Jan 05, 2011
    This is not a typical car stereo amp. It is 15-20 years old and utilizes pure class A circuitry. It is stable down to 1/4 ohm loads and cannnot be picked up on any street corner anymore, and for that matter any car audio supplier that I know of. While waiting for your answer I, by dumb luck, stumbled upon the engineer who designed and oversaw the production of these amps for years. He is now semi-retired and services these amps for 1/2 of what they are worth. I actually found one of these amps on eBay, which is rare, the other night and seeing the auction though and seeing what it sold for, he was right. Thanks for your time. If there is a way I can pay 1/2 of what I was willing to pay for a completely accurate answer for my situation I would be satisfied.
    Thanks,
    Khan Powell
  • 22,326 Answers
The cause was most likely that it was overdriven causing this power stage melt down ,best advice is to bin it as it will cost more in time and labour to repair than its worth ,these sort of amps can be picked up from local electrical retailer from 100euros ,by the time you locate components and then solder them in is it worth it ,unless you enjoy doing it and have nothing else to do on a dark winters night then please do so .
Posted on Jan 03, 2011
  • 4,924 Answers
Check the battery charger (alternator) and see if it is charging more than it should ..cause this is an issue due to a higher power shock ...and usually only the power supply will blow in this cases...replacing the parts should make it work ..Try to place a fuse on the power line for the future..same like the ones they use for the woofer amplifiers...
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
I have an old soundstream reference class a 5.0 and a set of mb quart pwe 254 10 duel voice coil subs. i would like to know how to wire this set up for the most power. parrallel the voice coils then run...
The Soundstream Class A 5.0 will deliver its full power at 1 ohms mono.
I think your subs are two dual 4 ohm voice coils.
If you wire the voice coils for each sub in PARALLEL, that's 2 ohm for each sub. To get 1 ohm mono, you need to hook up the subs in PARALLEL to the amplifier, in bridge mode. That's the way to get to 1 ohm mono. Please add a fan to your setup as the amplifier will get very hot. You will need to use a relay to hook up the amplifiers and fan(s) to or you will damage the remote ouput of your HU (if you hook up the fan straight to the remote of the HU) as the remote output of the HU is not designed for the amount of current a fan draws.
Good luck. If you need help with the relay issue, have a look here: http://www.caraudiohelp.com/newsletter/multiple_amplifiers.htm
Jun 27, 2011 | MB Quart PWE-254 Car Subwoofer
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Mar 18, 2011 | Soundstream Car Audio & Video
When bass kicks in amp dims car lights and car amp gauge reads very low. Ground wire is 6 gauge about 18 inches long, power wire is 8 gauge about 8 or 9 feet long. subs are wired according to owners book...
The problem is the amplifier is drawing more amperage than the alternator can provide. Install a capacitor in the battery feed line to the amplifier (can be purchased at any car stereo store). Do not go with the cheapest as this is a storage battery and like a battery cheap ones fail quickly.
Dec 25, 2009 | Lanzar MXA282 Car Audio Amplifier
I have a reference 700sx and the left channel does not work.I tried changing rca cables and also a different rca output from the deck.is there a place I can take/send it to be looked at and or fixed?
SEE MY ADD UNDER THE REPAIR FACILITY LISTINGS ON THIS SITE. MY CONTACT INFORMATION IS THERE. I HAVE A REFERENCE 700SX MYSELF ALONG WITH A FEW OTHER SOUNDSTREAM AMPLIFIERS. IF YOU CANNOT FIND THE ADD. YOU CAN EMAIL ME AT PROFSRVCS@AOL.COM. I AM NEW TO THIS FORUM AND I HAVE YET TO FIGURE OUT HOW TO DIRECT PEOPLE TO MY ADD IN THE REPAIR SECTION. THANKS......V
Dec 03, 2009 | Soundstream CAR AMPLIFIER, 4 CH, 120 WPC...
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Samson power amp capacitor?-HELP!!!!
Its samwha brand with a 100volt working voltage 6800 microfarad capacitance value its next symbols seems to me the chemical compositions or stock code, and its maximum working temperature. Could be a low ESR type capacitor.
May 14, 2009 | Alesis RA-150 Amplifier
Blown resistors in Soundstream Reference 300
Dude I hate to say this but the whole thing is shot. I am a solder/ board repair technitian for the US Navy and by looking at these pictures you have not only bad components but also a burnt borard. This is what they call a multilayer board which means there is more than one layer of circuitry. Looking at the resistors I am able to see the board waffers which means in order to repair this problem you will need copper to repair the tracks, small eyelets to replace the through-the-board solder joints, eppoxy, verry percice dremal tool, a steady hand, lots of patients and time. I wish that there was some good news to tell you but I am sorry. By the way the resistors appear to be about a 200 ohm resstor with a tollerance level of +/- 10%
Mar 30, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Protect light stays on
It's likely that the output transistors have failed. If you measure the resistance between the second and third legs of the large transistors adjacent to the large (green?) resistors, you'll find several that read ~0 ohms. Its likely that only one of several that read 0 ohms is defective but all that read 0 ohms in the board are operating in parallel and must be replaced together so they match (electrically).
Disconnect the amp from the power source BEFORE trying to measure the resistance across the resistors.
Nov 25, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
