Question about Compaq Computers & Internet
Disk drive wont open/eject computer says no cd drive detected also says this drive is running properly w/ most current updates
  • dudebro79 Jan 03, 2011
    this was helpful but does not solve the overall problem of the computer not detecting the cd drive as well as not detecting any type of disc
  • 162 Answers
There should be a tiny hole in the cd drive get a paper clip and push it it will open the cd draw
Posted on Jan 03, 2011
Bd rom wont eject
If it does not eject, how does it open?
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Computers & Internet
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
Tray wont open device mgr says working properly
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Feb 13, 2012 | Computers & Internet
I got a problem with my hp external dvd drive, unable or failed to eject. I checked the properties and it indicates there that the device is working properly but still failed to eject. Could you pls. help...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 22, 2011 | H45 Quick DVD External DVD Drive
My Iomega CDRW64001 keeps ejecting my blank CDs. The external LED blinks for several minutes and then ejects the CD with or without a burn program open. It plays recorded CDs and I'm able to install...
Your best solution (since your USB devices and your network-adapter are not working) is to remove the disk-drive from the old computer, and temporarily connect it as a "slave" disk-drive in the new computer, and then copy all your files from "old" to "new".
Or, try a different brand of "blank" CD-R disks -- the "firmware" (software inside the CD-writer) may not be recognizing "newly-manufactured" media). Unless you can update the firmware (by downloading the latest firmware on another computer, and burning a CD-R disk, and then taking that disk to your computer), it's easiest to "move" the disk-drive to the new computer.
Jul 16, 2010 | Iomega (32885) CD-RW Burner
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
Code 19/ its not reading only ejects when comanded manually. Cd DVD problem
try reseating the connections from the motherboard to the disc drive. if it wont work try to uninstall and then reinstall it from the device manager by restarting it (but check f it is being detected in the device manager). if still not running properly a firmware update for the drive will possibly resolve the issue. you can also try running diagnostics on the drive and checking on BIOS if it is being detected. if any of the mentioned solutions won't work, then a optical drive replacement will be the best resolution.
Feb 26, 2010 | Dell Vostro 200 PC Desktop
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
My sony cs11s wont let me make recovery discs lets me get to 12% and then ejects disc
Make sure you have the notebook plugged in (some recovery disk software will not run until this is done).
Stop any running processes (such as antivirus scanners and screensavers.
Sometimes changing the brand of disk makes a difference, too. Some drives are picky about what they burn to. The more opaque the disk, the greater the success in burning.
Do a test burn and make sure the drive is working properly--make a music cd or copy an unprotected cd and see if this process fails.
Finally, check to see if your burning software has the latest updates. The burning engine in the recovery disk software may be outdated.
Good luck and keep us posted.
Sep 24, 2009 | Sony VAIO Notebook
LG Combo Drive
Try uninstalling the current driver, then applying the updated driver, worst case scenerio is you get the current driver again
Jan 29, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Computers & Internet Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
