Question about Simplicity Baby Gear
How can I order new sheets for my bassinet? reg # CA37465(PA)
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
Where can i find the bedding for the eddie bauer bassinet? i only have the bassinet not the bedding.
Most baby stores (Babies R Us, BuyBuy Baby, Toys R Us, etc) carry bassinet sheets. They have elastic edges so they fit most sizes. I found that for my granddaughters abssinet, there were few color choices so I used pillowcases and tucked the excess under the mattress. Other than that, if you want something made specifically for your brand, generally you'll need to contact the manufacturer or make it yourself.
Apr 21, 2010 | Eddie Bauer Musical Rocking Bassinet...
I lost allthescrews and hardware for my changing table
call the 1-800 number and they will send you all new hard wear I had to do the same thing with my crib moving from Fla. to PA I lost my screws.. they sent me a set I had to pay shipping
Oct 27, 2009 | Evenflo Jenny Lind Crib
Bassinet canopy
You may be able to order one through the shop you brought it from or you can use a net curtain which may be cheaper
Feb 12, 2009 | Eddie Bauer Musical Rocking Bassinet...
Simplicity 4 in 1 bassinet
I need instructions to back together the 4 in 1 bassinet
Thanks,
Mary
Jan 05, 2009 | Simplicity for Children 4-in-1 Convertible...
Kolcraft Bassinet
it is warped, it should be flat, but as long as it's not too bad, it should be ok for use.
Nov 24, 2008 | Baby Gear
Replace parts
call 18005441108 -- they will provide you with any replacement part needed -- just have credit card ready!
May 07, 2008 | Eddie Bauer Musical Rocking Bassinet...
Building the simplicity 4 in 1 convertible bassinet HELP PLZ!!!!!!
You may find the following link helpful, as it has video instructions on how to set up the configurations.Hope this helps and let us know if you need further assistance.
Apr 18, 2008 | Simplicity for Children 4-in-1 Convertible...
Baby Gear Logo
35 people viewed this question
Top Simplicity Baby Gear Experts
Scott Jelt
Scott Jelt
Greg Cann
Greg Cann
Jason Morris
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
