Question about Sakar Computers & Internet
The right click button on my mouse doesn't work. no response from any input.
    Sergeant:
    Champion:
  • 342 Answers
That happens after a few years sometimes you might have to replace the mouse it is easier but all they usually need is a replacement switch but it is still cheaper to replace the mouse
Posted on Jan 03, 2011
The left click is not functioning, right click works just fine but left click has no response whatsoever.
Usually either the lever (button) has slipped out of it's pivot point, the spring has come out, or the switch below the button is broken. To check, look around the edges for a small screwdriver slot or small screw. Open the mouse. Look at the button to see how it pivots. If on opening there are small pieces of plastic, discard the mouse. if it has just slipped out of its spot, realign and close the mouse, it should be good to go.
Mar 22, 2015 | Logitech LX3 Optical Wired USB Mouse Grey
Why my microsfot wireless mouse 3500 stop working ?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Hope this helps.
Jan 22, 2013 | Microsoft Wireless Mobile Mouse 3500 Sea...
I have a problem with the mouse for 5euro This technique tknm110 mouse and the problem that I have a normally lit mouse is a optical mouse, but mouse does not work ... it's two the same, at first I...
Hello ania1997,
I've seen this 'problem' before.
First, disconnect the "Mouse."
Next, click on the "Start Button."
Now, click on the "Control Panel," in the 'start menu'.
Scroll in the Control Panel, and select the "Mouse" applet!
Open the [Mouse Properties], by 2x clicking or,
Right clicking,and open.
From here you want to [Disable the Touchpad Device].
!Beware, that now, you may have to "Manually Navigate."
Without the 'mouse; you will use the "Tab, Arrows, and 'Enter' buttons,
to perform tasks, if the 'optical mouse' doesn't work the first time.
"Restart the computer."
Connect the "Optical Mouse."
"The {Mouse should be detected automatically}."
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Computers & Internet
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont...
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
I bought a cordless mouse Fha 3410. When I let down the left click, it acts like double click, so do not let me select objects. I need to solve this problem, since I can not work normally in any...
Hi..
Go to - Devices and Printers in Control Panel
Go to - Mouse properties and check for the Doubel click speed.. See to that it is not set to the max.
May 30, 2011 | HP Wireless Optical Mouse
My netbook got wet. Now the number buttons don't input one number they input three of the same number. My left mouse button doesn't click it is now working like the right mouse button. HELP???
I suspect that your net book has not dried out completely and has left a moisture trace on the membrane keyboard that is shorting to another trace. Heat the oven to 100 degrees (caution, do not go over 110 degrees), and place the net book in that 100 degree heat for a few hours. Hopefully any lingering moisture will evaporate and leave the key traces clean.
May 18, 2011 | Sylvania G-Netbook
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Toshiba Satellite ?Vista home?Start button not working
> clicking on START has no response.
Have you tried a different mouse, just in case that the LEFT button on the mouse is malfunctioning?
Does pressing the "Windows-flag" key on your keyboard (between CTRL and ALT, on the left) cause the same effect as clicking the START button?
Start Internet Explorer.
Click Tools.
Click Internet Options.
Click Connections
Check that your PPoE entry is present and is set to "automatic".
Nov 19, 2009 | Microsoft Windows Vista Home Premium with...
I can't get the mouse on my laptop to work right. The right clik button does what the left click button should be doing but the left click button does not work on the game only.
go into settings then control panel on your desktop and look for device manager then go to mouse input the settings have probley been changed for the button config ther first setting is to swap button functions. check to see if they are set correctly for left primary. this sometimes happens with games... you can also check mouse settings on teh game itself look for settings and then input. Good Luck A
Aug 11, 2009 | Global Star Software John Deere American...
Computers & Internet Logo
71 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Ravi
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
