Hi no power going in to the TV, checked plug changed socket any idea's?
  • 8,617 Answers
Have you checked the fuse? Please respond to this same post with your model number and I will try to assist you.
Posted on Jul 09, 2008
I plug out my lexsor tv and when pluged back in it wont not come back on. I change fuse in plug also still nothing
Hi Katie,
Please have the power cord checked. Sometimes it goes bad while pulling out from wall socket. If that is ok then it is the power supply board which is not working.
Good luck.
May 13, 2015 | Televison & Video
Alba tv blowing the 12v dc adaptor
Check the adapter itself bow out, when it is plugged to Wall AC socket. Do not load it to TV, and check this. If it blows up, the fault is with the adapter itself. If it don't, the fault must be within the TV circuit.
Jun 18, 2013 | Televison & Video
Toshiba 42hl800a won't power on
Hi, first plug in another appliance, hoover etc to check if power is available at the socket, then, check / change fuse in the plug / try a suitable other lead with similar end socket, most are standard fitting, only then if you are confident/competent, remove back of TV where you will find another quick blow fuse
Apr 17, 2012 | Toshiba Televison & Video
Two sockets in room.. 1 socket connects the TV directly .. yes i did not know it was safe :(... the other socket has like an extender then multiple sockets. plugs the ps3 wire into a plug then into...
Hi, I will suggest that you have those plugs checked out by a electrician. You could have a fire if you continue. Also you may not have enough power to run your TV. Good Luck
Sep 10, 2011 | LG 42LC2D 42 in. LCD HDTV
No power indicator ever printer is plugged in
1.Check power cable plugged in correct way
2.determine power supply is up to that socket
3. change power cable,if extra cable with you
4. may be its hardware issue inside the printer
5.go to shop and check.
Thanks and Regards
Trinoj
Aug 05, 2011 | Computers & Internet
Hello my name is chris. i recently moved into a friends house and i transported my tv to his house. lg sl80. well when i get in there i plug it in and the red power light doesnt come on. any suggestions on...
Hello Chris.
I would double check the power lead (and fuse if in UK).
Check also the socket is working or try another power socket.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | LG 47SL8000 47 in. HDTV-Ready LED TV
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
I have hooked up my computer to my surround sound system and now i get a loud buzzing sounds I have bought new rca checked eveything even hooled it up to a diff one ..then the tv I can't get rid of it..i...
The buzzing sound could be from what they call a Ground Loop.
This is cause by plugging in Hi Fi and computer devices etc. into different mains power sockets.
The way around this is to use a power board and connect all your devices into the power board and plug the power board into a single power socket.
May 18, 2009 | Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB...
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
