Question about Sony KV-36XBR450 36" TV
My sony kv-36xbr450 wont come on. When I plug it in I hera a clicking noise and once I press the power button the picture flashes to come on but doesnt and turns off by itself
  • 1,557 Answers
The main strike relay is turning on the power board but the tube relay is detecting a fault when it trys to ingage the unit needs to be fixed by a lic pro there is no easy fix to this fault
hope this helps
Posted on Jan 03, 2011
SOURCE:
Sony kv-36xbr450 36
breakdown in the horizontal, check the c515, c516 and the jungle ic IC206 which get bad.
Oct 27, 2012 | Sony KV-36XBR450 36" TV
My sony kv-36xbr450 quit responding to the remote (rm-y184). I put new batteries and the remote lights work when pushing buttons. Is there a way to reset or check the remote ?
it is most likely the remote receiver inside the tv. you can verify this by using a universal remote. if you cant get it to work the receiver is bad.
Dec 27, 2009 | Sony KV-36XBR450 36" TV
Sony KV-36XBR450 seems to turn on but screen slightly pops white around edges but immediately goes all black and will not show a picture.
According to the symptom the problem seems that the high voltage cap is loose and not plugged properly. For your convenience see the below pic and reset it. The number 11 is the target component in pic. Hope this will solve your problem.
Note: This component has a high voltage, please don't forget safety measures.
Thanks for using fixya.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
Power clicks on and red power light flashes but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
Aug 11, 2009 | Sony KV-27S46 27" TV
Kv-36xbr450 picture freezes or wiggles
Check the cables going in and out of the tcon board if that doesn't fix it replace that board
Nov 25, 2017 | Sony KV-36XBR450 36" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
36XBR450 fix myself?
Most probably,the secondary power output of your TV's switching power supply is not functioning.You have to trouble shoot the secondary power which also leads to HT supply in the Horizontal circuitry.
Apr 01, 2008 | Sony KV-36XBR450 36" TV
Sony 36XBR450 power?
You will not be able to service this at home. Most of the time there are failures in the scan amplifiers and or the power supply that cause the fault you are describing.
Jerry G.
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-36XBR450 36" TV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
