Question about Dell Inspiron 5100 Laptop
Does not recognise ac adapter - Dell Inspiron 5100 Laptop
    Genius:
  • 2,028 Answers
Could you please give more info to what it's doing exactly?
Posted on Jul 09, 2008
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
Red indicator blinking
does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
Aug 09, 2014 | Dell Precision M4300 Laptop AC Power...
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
When i plug my camcorder in to the computer via the usb its not recognised and the on screen menu tells me to plug in an ac adapter
Some camcorders require you to have the ac adapter plugged in to keep your camcorder on so that you wont loose any data if the camera dies during the transfer to computer process. You can check the Panasonic website for up to date drivers for the operating system you are using. I hope this helps.
Sep 06, 2010 | Panasonic Video Cameras
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
Adding to ubuntu desktop
it could be that power isn't sufficient on the USB connection. you might need to plug in your AC adapter.
Also this drive has both FireWire and USB ports on it.
To get it working, make sure that the AC adapter is supplying power, and that USB is connected correctly, then re-boot.
Ubuntu should recognize the drive.
Command line tools that may help are
lsusb
this shows which devices are connected via USB to your computer.
dmesg | less
will help you look for the drive's identification and recognition by the computer, providing information such as vendor strings, capacity, and device assignments.
Good luck.
Mar 23, 2010 | FireLite (USBFLB80) Hard Drive
Charger not recognised
I believe this is a known problem, all you have to do is to Download and install the BIOS update on the support website support.dell.com . After installing the BIOS update and still the charger is not recognized, it only means the motherboard needs to be replaced as well as the ac adapter. If you are still covered by the warranty, call dell tech support and they will replace the motherboard and ac adapter.
Hope this helps.
Jan 16, 2010 | Dell Inspiron 1501 Notebook
AC adapter not recognised
Try charging the battery on one of the other dell's.
If the unit runs for any lengh of time, it is not the motherboard.
It could be the A/C adaptor jack on the side of the unit.
Log a complaint will dell's customer care.
Sep 28, 2009 | Dell Inspiron 6400 Notebook
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
AC adapter power not enough for XP?
I use WINXP Pro and there is no problem. I can only offer the steps that I use for you to see if it makes any difference. Sometimes the sequence can be the answer.Try this twice, once with the battery in the adapter and once without the battery.
1. Power down PC.
2. Disconect camera from PC.
2. Power up PC.
2. Make sure the camera is off.
3. Remove battery from Camera.
4. Plug adapter into mains (with or without battery)
5. Plug camera into adapter.
6. Plug camera into PC with firewire.
7. Switch Camera on
Dec 03, 2006 | Panasonic NV-DS27B Mini DV Digital...
Dell Inspiron 5100 Laptop Logo
26 people viewed this question
Alun Cox
