Question about Kirby G4 Bagged Upright Vacuum
Fan blade cracked - Kirby G4 Bagged Upright Vacuum
  • 694 Answers
It needs replaced before it breaks and pieces get into the motor.
Replacement instructions can be found at http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html.
Posted on Jan 03, 2011
Fan housing broke on our xl21 600ecc
If you take it to an Oreck dealer for repair you will probably get both because the fan housing usually comes with a new fan. Usually a fan housing will only break if something was picked up that the blades flipped it into the housing with enough force to crack it. You may find that depending on the dealer it may not be covered under warranty. I work at a dealer on weekends and work on these machines and have seen this frequently, I would recommend replacing both if you are able to get them separately.
Mar 27, 2014 | Oreck XL21 Bagged Upright Vacuum
Very poor suction
Make sure ALL the air passageways are not blocked with any hair, dust balls or other material. If they are ALL clear, then it's probably the fan blade that creates the suction is damaged, maybe a blade or two are broken. It is cheap to buy a new fan blade, but taking the machine apart and replacing the blade would be moderately expensive for a repairman. Maybe you can try to do that yourself. If not, always ask for a complete estimate for the repair, and have it written out on paper before you agree to the work.
Oct 18, 2013 | Dyson Vacuums
Roomba 550 stops after 30 seconds of operating. Battery was replaced 1 yr ago to the date. Also makes screeching noise. Did clean the gear box in 1/13 but didn't put lube on gears.
OK, then maybe you should diassemble the machine and put some lubrication on the gears. Make sure everything is in it's correct place when re-assembly. Make siure the fan blade that creates the suction isn't damaged or even cracked. If it is, replace it. If it's stopping shortly after starting, it may have something OUT OF PLACE, that's causing to much friction.
Oct 15, 2013 | iRobot Roomba 560 Robotic Vacuum
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
The piece under the blades cracked can it be replaced with out buying the whol blender
You can try removing the blades and put apoxy in the crack and let it dry. Put the blade back on and make sure the blade does not rub by turning the blade by hand to see if it turns smoothly. Do all of this while the blender is unplugged.
Mar 11, 2011 | Vacuums
How do you clean the fan blades on a humudifier
Hi and welcome to FixYa. I am Kelly.
I do this all the time and it works well for ALL types of aluminum fan blades on any appliance.
Use an older piece of Scotch-Brite with soap & water (So you do not scratch up the blades) then wipe it off with a damp rag then a dry rag. Just make sure you do NOT get water in the motor bearings. Place the blade your cleaning below the 3 or 9 o'clock positions to avoid introducing water into the motor bearings. Also do your best NOT to bend the blades in the process of cleaning.
Thanks for Choosing FixYa,
Kelly
Feb 16, 2011 | Vacuums
I just got the majestic and it doesn't seem to have a lot of suction power- I ran water thru the hose and it drained out fine I also put the hose on top and blew it out. Could it still be the hose?-or...
Did you change the filter cone? Clogged pores can and do inhibit airflow. Bent fan blades can be another problem. Holes, slits, and cracks, no matter how small, in the hose can result in reduced suction.
And you should NEVER run water through a hose that contains electrical wiring, which I suspect yours does.
Oct 15, 2010 | Filter Queen Majestic Canister Vacuum
The vacuum has started making a much louder noise. like something is coming apart or is stuck/clogged. Noticed the fan type blade has several cracks, some bigger than others. could this be the problem?
Yes, this is very likely. The fan is made of plastic, because a metal fan would be so heavy that it would make the motor burn out unnecessarily fast. Sucking up things like loose change, pebbles, screws, etc. can crack the fan, and unfortunately this requires the front part of the motor to be disassembled. I'm pretty handy with Kirbys but I wouldn't attempt this type of repair myself. Best to leave it to a professional.
Do be sure to remove the em-tor unit (the plastic part that attaches to the blower in back) and check to make sure no large items are rattling around in there. Just unhook the bag clip from the handle, grasp the em-tor unit at the base and turn firmly but gently. When it pops off, all the things that were too heavy to get sucked upward into the bag will fall out. This might help, but it is not recommended to run a Kirby with a damaged fan. It is bad for the motor.
May 24, 2010 | Kirby Heritage II Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
Kirby G4 Bagged Upright Vacuum Logo
60 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
