Question about Gateway FPD1760 Monitor
Gateway fpd1760 tft lcd color monitor i not warking
    New Friend:
No prende
Posted on Sep 15, 2012
    Guru:
  • 679 Answers
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Posted on Jan 03, 2011
SOURCE:
FPD1760 17" LCD Monitor/driver download
Go to the online site that supports the monitor (depending on how old the unit is, it may not be available anymore).
Jul 06, 2014 | Gateway FPD1760 17" LCD Monitor
I want to put my laptop and connect it with Gateway monitor. What type of plugs do I need?
Spec of the monitor http://www.dealtime.com/xPF-Gateway-Gateway-Monitor-FPD1760
It will need the VGA cable (3-row/15-pin D-SUB), you need to look at your laptop monitor port to see what you have for the output.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
And you will need to set the laptop video signal to be at the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Sep 10, 2010 | Gateway FPD1760 17" LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway fpd1760 lcd monitor no power at all the blue led clicks on for 5 seconds the screen flashes for a milla second then nothing
check if the signal cable has been plugged in properly at the back of the screen and at the back of the computer.
if you have another computer or laptop,.check if the screen works fine with it.as this could even be a boot up problem with the computer
Feb 04, 2010 | Gateway FPD1760 17" LCD Monitor
I have a Gateway FPD1760TFT LCD color monitor. I
What is the display resolution you have set in your display properties? For this monitor it should be set to 1280x1024 pixels, which should give you proper screen geometry.
Jan 24, 2010 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Your graphics card is not working propertly buy a new one.
Mar 15, 2009 | Gateway FPD1760 17" LCD Monitor
My Gateway FPD1760 Won't turn on.
Inverter or Inverter boards Blown.
Hope this helps.
Mike @ compurepair.
Feb 23, 2008 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Driver for FPD1760
Please feel free to download your drivers through google.com...
Aug 24, 2007 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
319 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
