Question about Brother MFC-9840CDW Laser Printer
What does Print unable 71 mean and what do I have to do to correct the problem?
Error code 71
Print Unable 71
Turn the power off and then back on again.
Polygon motor failure
Posted on Sep 07, 2013
    Sergeant:
  • 358 Answers
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays "MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Posted on Jan 03, 2011
2 Suggested Answers
SOURCE: unable print copy 71
Sir/Madam
The machine has a mechanical problem.
Turn the power switch off, wait a few minutes, and then turn it on again. If the problem continues, please call your dealer or
Or Follow Us For Online Brother Printer Support
Posted on Jan 08, 2014
How to solution printer unable 71
https://www.manualslib.com/manual/794794/Brother-Dcp-7055.html?page=81
Dec 02, 2016 | Brother Office Equipment & Supplies
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
Unable to print 34 (what is it and how to correct)
This means there may be a paper or object like a paper clip inside the printer. Have you just had a paper jam?
Open the unit and inspect for paper or an object.
Follow the directions in the manual regarding saving any unprinted faxes, then disconnect power for ten seconds. Plug the unit back in. It should be working.
Oct 13, 2014 | Brother Office Equipment & Supplies
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
What's your problem?print unable 71 dcp7065 dn
I recommend that you will post your question under the correct category (printers) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
You can also contact the Brother site directly at http://www.brother-usa.com/askus/default.aspx?PGID=1&R3ModelID=1814#.UIU9F6Puj_Y
Jun 19, 2012 | Furniture
Printer message "unable to print 36"
That error usually means a paper scrap or something is stopping the carriage from moving across the paper correctly, or there are scraps caught on either side of the carriage assembly.
Aug 28, 2009 | Brother MFC-465CN InkJet Printer
GOT ERROR 71 PLEASE HELP
any of the error 7X codes are to do with the fuser. Call an engineer
Jun 04, 2009 | Brother MFC-8220 Fax
Brother MFC-9840CDW Laser Printer Logo
4,757 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
