Question about SmartDisk FireLite 40 GB Hard Drive
I have been using my SmartDisk FireLite external hard drive on my macbook for about a year and a half and it stopped working today. The yellow light on the front lights up when I plug it into my firewire--it is like it is on, but the orange light on the back does not light up. Sometimes the external hard drive shows up as a device and sometimes it doesn't. When it shows up, it will randomly stop working and the orange light will flicker on and off. It seems like it will randomly work and different angles, but not consistently.
  • Anonymous Jan 03, 2011
    There is no clicking, so could it be something else???
  • 536 Answers
If there is a repeated clicking noise from the drive, then the drive has head-crashed. If there is any data on it that you absolutely have to have, then stop using the drive immediately and contact a drive recovery service like DriveSavers.
Please do not give me a bad rating for being the bearer of bad news. I'm trying to save your data by being direct with you. Others might try to paint a rosy picture about this situation to get a good rating, but the fact of the matter is that you need to disconnect the drive immediately if there is anything of value that you need off of it.
I've used DriveSavers in the past and they are very reputable: http://www.drivesaversdatarecovery.com/
Give them a call to discuss the situation.
NOTE: there are many drive recovery companies out there that are probably just as good as DriveSavers. My only experience in this situation has been with DriveSavers, so that's why I mention them. I do not work for or have any connection to them aside from having once been their customer.
Posted on Jan 03, 2011
  • 1 more comment
  • Jeffrey Groves
    Jeffrey Groves Jan 03, 2011
    If there is no clicking, then there is probably a loose component inside the drive or in the enclosure causing the problem. I say this because you said that changing the orientation of the drive sometime allows it to work for a while. If it is a loose component and not a head crash, then that is much better news for your data if you decide to send the drive off to a drive recovery service.
  • Jeffrey Groves
    I had another thought. Can you try using a different data cable with the drive (if that is even possible}. A failed cable could also be the problem here.
    I definitely do not have another cable to try. It could be the cable and while it doesn't sound like there is a loose part inside, it could also be that. When I plug it in, the fan runs like it really wants to work, but it is not recognized by my computer.
My external firelite model #USBFLB40, stop work today, i tried in other laptoop, and its work but after i disconnect, i want to used it again, and dosent work, ether my lap, nether the other lap... ...
1. It may be due to the electronics in the USB case.
You can purchase a new case and install the hard drive and connect to the USB port to your laptop/PC.
If the drive is not seen after this then the drive itself may be damaged.
If you disconnected the USB drive without "safely removing it in Windows it may have damaged the hard drive controller.
Mar 18, 2011 | SmartDisk FireLite 40 GB Hard Drive
Computer repeatedly requests restart when smartdisk plugged in
try to scan your smart disk to another computer, your hard disk just hit by a trojan virus
Jun 28, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Firelite hard drive won't mount on a Macbook
Sounds suspicious, have a look at other world computing, they have all sorts of work rounds for apple limitations. Have you looked in the disk utility to see if it is there? if so run repair and permissions.
Jan 25, 2009 | SmartDisk FireLite 80 GB Hard Drive
How to back up photos on MacBook
From within iPhoto, try saving/exporting directly to the drive.
Jul 09, 2008 | Verbatim SmartDisk Firelite Portable USB...
Smartdisk Firelite 80GB-Stopped Working
I had the same problem with my firelite usbflb80-c, and carefully took the case off, 4 screws (one screw under the void if broken warranty sticker) my drive had somehow wiggled it's way out if the connection pins. Figures, with 5 yrs of use, all the traveling and occasional dropping. So I carefully pushed the drive back in place until I couldn't see connection pins any more. I plugged it into my computer before I closed it back up. THANKFULLY an easy fix, but I double checked for breaks or cracks before I closed it up. :o) YAY, I thought I had lost all my files!
Jan 15, 2008 | FireLite (USBFLB80) Hard Drive
All Information No Longer Available
Email me at fixya-expert@live.com and i will send instrucions how to fix it
Beni
Nov 21, 2007 | SmartDisk FireLite 60 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
364 people viewed this question
Top SmartDisk Computers & Internet Experts
terminalcon
Dennis Crouse
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
