Question about Whirlpool Duet GHW9150P Front Load Washer
Hi, During the spin cycle the inner drum slams against the inner plastic rim and the plastic started ripping off. I can't figure out why it is off center
  • 347 Answers
Your problem is the rear drum support , This is not worth repairing its less costly and wiser to just replace it..Below are some examples of the issue
Been seeing a rash of galvanic corrosion-induced failures of the drum support spiders in various brands of front loading washers. Affected brands include GE, Whirlpool, and Frigidaire. Since Sears Kenmore brand outsources everything with a Kenmore label, all Kenmore washers are manufactured by one of the three aforementioned companies and will also manifest this same problem (see this topic for more info on who makes Kenmore appliances).
Kicking off the Washer Corrosion Hall of Shame is this bit of metallic misery from a Frikkidaire washer:
The drum support spider in this Frigidaire washer had corroded so much that the hub and drive shaft actually broke off. Note the pitting in the metal. You can see in the closeup that the metal seems to turn into powder. That's the galvanic corrosion that I be tawkin' aboot, you dig? It weakened the spider structural strength so much that it failed during use. Ah, Grasshoppah, can you stand with me, our mouths agape at the raw power of chemistry?
Next up is this drum from a GE washer:
Not to be outdone by their competitors, here's an advanced case of galvanic corrosion in a Whirlpool Duet washer (also sold as the Kenmore HE2/3t):4054175658_b61621ef65_m.jpg
(click images for larger view)
Whence cometh this galvanic corrosion? Most likely because of dissimilar metals between the spider assembly and the drum setting up a galvanic cell inside the washer. The drum is stainless steel and the spider is aluminum. In the wet environment, the aluminum acts as a sacrificial anode, like the zinc rod in a water heater. Some combinations of detergents, fabric softeners, and water quality conditions may create electrochemical conditions which exacerbate this problem. Can you say, "Design flaw?"
Posted on Jan 03, 2011
  • 472 Answers
Sounds like you have a shock broken on this unit... may want to remove fron t kick plate usually has 2 or three screws at very bottom of unit and inspect... if all loks good there then it is possible that the counter weight located on top of unit is damaged. you will have to remove top of washer to inspect this area and is usually made of concrete material...... good luck to you....
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
When spinning drum is slamming against washers sides. Can this be fixed
This would be an out of balance issue. Level your machine first and then make sure you load it evenly when adding clothes.
Apr 05, 2016 | Washing Machines
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
During the spin cycle it sounds like the drum is about to come out of the machine and there are little grey plastic pieces in the clothing.
Sound like the basket has broken away from the spinning support coming of the back of inner drum, Gray plastic is the front ring the inner tub is now rubbing on. This has been making noise for a while. Phil 1-800-559-1411 www.phils.com any help I can give you.
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Inner drum
Sounds like a loose or busted belt.
Nov 05, 2007 | Maytag Performa PAV2200
Drum sounds like it's rubbing against metal
hi there....sounds as if youve got a bra wire etc trapped between the outer and inner drum..open the appliance door and carefully examine the inner drum you will possibly see the offending wire protruding from some one of the holes in the drum...it can either be removed by juggling it out or having an engineer remove it for you regards Sir Galahad
Dec 28, 2006 | Creda W120VW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
263 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
