Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet is giving f 02code....can anyone tell me what this means please...thanks
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F02 is a drain error
Remove the bottom front panel and there was a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean the debris out.
Posted on Jan 03, 2011
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet is giving a code of F 21. what does that mean and how do i fix it?
Hi
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 18, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Year of Manufacture
Look on page 1-2 of the attached for details on how to decode the serial number:
http://adcxns1.whirlpool.com/Service...0Job%20Aid.pdf
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HELP WHIRLPOOL DUET
post me your email here and
I will send you a PDF of the service manual
Thanks Gary
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What does this cod mean?
Post you email i will email you the PDF of the service manual but the only code i see is a F which equals FAULT the the "code" is H which is a no water detected entering the machine or Pressure switch trip not detected
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Model #WFW8300SW Error code F then 20, what does it mean ?
does it do this a lot dont rate me till were done give me your complete model number
Jan 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
313 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
