Question about GE GSS23SGSSS Stainless Steel Side by Side Refrigerator
Ice maker had frozen buildup that has been removed. 24 hours later, it is not making any ice.
  • 32 Answers
Water supply line maybe frozen use a hair dryer and warm up area of icemaker and supply lines that shouls solve it
Posted on Jan 03, 2011
For the past month the ice maker is not dispensing ice cubes. The water supply valve is turned on, there is no kinks in the water source line and the ice maker is turned on. I ran out of ideas. Do you have...
Hi
The water tube that supplies water to the ice maker is possibly frozen up.
The way to check this is to empty all food out of both sections and store alsewhere, then turn off and unplug the unit. Wait for 24 to 36 hours with the doors partially open to allow all the ice to melt.
Change the water filter and plug in and switch on.
Run off around a gallon of water to prime the system. You should then get chilled water around 4 hours later and ice after 12 hours.
If there is still no ice you may find that the trace heater on the ice maker water tube is faulty and may need to be replaced
Regards
Gordon
Apr 24, 2011 | Refrigerators
My side by side is not making ice. I can prime it and get ice, it will not make it on its own. Any Idea ?
Push the wire shutoff arm down to place it in the "On" position,if applicable. If the ice maker has a switch on the side, place it in the"On" position. Wait 24 hours after the refrigerator is installed for ice production tobegin. The freezer section must cool down to the correct temperature. (5 degreeor less) If a large amount of ice was removed from the bin, allow 24 hours forthe ice maker to produce more ice. Follow the water source line on the back of the refrigerator to the shutoffvalve on the water supply. Turn the shutoff valve counterclockwise to open itfully. Inspect the water source line for kinks. Straighten the line to removekinks. Scrape the ejector arm with a plastic utensil to remove ice buildup.
Jan 28, 2011 | Frigidaire FRS3R5EMB Side by Side...
The ice maker making noise and doesn't make ice, it seems like it si frozen
Good day,
Remove the ice maker( three clips or screws and a wire plug), and set it on a counter for 24 hours to dry out.
Reinstall and test. If that doesn't help, you'll need to replace the ice maker, and I recommend you install a new water valve at the same time.
Thank you for using FixYa
Jan 14, 2010 | Whirlpool Refrigerators
Remove door and icemaker from bottom freezer model 59673914200 -- icemaker wont turn
The ice maker switch had come unattached due to excess ice buildup, and frozen to the ice pack. The ice in the ice maker had also frozen into a solid block due to not being able to rotate. After removing the drawer trays and protecting the frozen food, turning off the refridgerator, I used a hair drier to melt and remove the ice from the ice maker, gave it time to dry out, -- No gears wer stripped,- the ice maker now works normally.
Aug 23, 2009 | Kenmore Refrigerators
An apppliance company has installed three ice makers and none of the three have worked. they may drop ice once or twice in a 24 hour period. there is also frozen water in the ice bin. Can you tell me what...
you can make ice at30/31 degrees F but ice makers do not start until it is 0/4F clean all coils and if it has a condenser fan see if it works or you may be just low on freon thumbs up
Aug 12, 2009 | Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Attaching icecream maker
KitchenAid Ice Cream Maker Attachment:transp.gif
Convert any KitchenAid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all KitchenAid household stand mixers.
Includes:
  • Double-walled Bowl
  • Churning Blades
  • Basic Recipes
    Instructions: The freezer bowl must be frozen for 18-24 hours prior to first use. Before each use, bowl must be completely frozen. Cycle time: 30-min. for soft-serve ice cream. For firmer consistency put in freezer for 1-2 additional hours.
  • Mar 02, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
    Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
    Turn ice maker off for 24 hours to thaw out any additional frozen lines.
    Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
    Feb 29, 2008 | Refrigerators
    ICE MAKER AND WATER SUPPLY DOES NOT WORK
    I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
    Thanks pete5runner!!!
    Feb 18, 2008 | Refrigerators
    Open Questions:
    GE GSS23SGSSS Stainless Steel Side by Side Refrigerator Logo
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
