Question about Broan-NuTone (668RP) Fan
I have three of these light fan combos in my home that I built in 2007. The fans seem to work okay. One of the lights works intermittently and one does not work at all. Where can I buy new light socket housings for the existing fan light combo?
    Scholar:
  • 130 Answers
Go to the website: http://parts.broan-nutone.com/broan/Shop
Posted on Jan 04, 2011
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Sep 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
My casablanca fan/light wall switch only works
No . have this checked by a licensed professional it is more than likely bad switchs in the fixture but you can never be to careful with electricity
Aug 23, 2009 | Dryers
Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Have hazard lights but no running or turn signals
sounds like you need a combo flasher assembly..located in fuse block inside vehicle under steering column..there may be a plastic cover under dash you have to remove to see fuse block..large black relay that plugs into fuse block..if you pick up a new one,you will see what it looks like..available at dodge dealer..combo flasher or drl/signal relay
Jun 11, 2009 | 1999 Dodge Caravan
Three lights on dashboard -engine, battery and ???
It is you serpentine belt most likely. See my previous post.
Mar 04, 2009 | 2002 Toyota ECHO
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote problems
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. Some things work, others don't, and others only intermittently. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
May 19, 2008 | Hampton Bay 24002 Ceiling Fan
Broan-NuTone (668RP) Fan Logo
248 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
