Hello ive got a URC 11-1031 R00 one for all remote control and i dont have the codes to set it up for my AGER air cond..both remotes where working last year..any help with resetting them up would be great..thanks and happy new year
IrishDruid
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
SOURCE: FUJITSU SPLIT AIR REMOTE CONTROL PROBLEM
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
Posted on Jan 27, 2009
lenwest
  • 150 Answers
SOURCE: Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Posted on Jan 30, 2009
free2rhyme
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Posted on Mar 25, 2009
How doi get the code for an alba to to use on universal remote control urc 11-1410 r00 and how do I do it
Use code search on your remote to find something that handles some or all functions of your Alba.
Dec 01, 2016 | Televison & Video
Where can i find set up instructions for a Total Control URC 11-2910-r00 remote control
The URC website will have everything you need. I am a URC dealer so let me know if you cannot get it and I will assist you further.
Dec 15, 2015 | Televison & Video
MANUAL AND CODES FOR URC 2891 R00
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Mar 10, 2014 | One For All URC-3021 Remote Control
How to tune one for all control URC 11-7110 R00
Set-up procedure is too much to type in here, and is not practical. Will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Feb 08, 2014 | Televison & Video
Manual for URC-11-2840R00
how do you set up a Total control 4 way remote silver
Mar 19, 2010 | Universal Remote Control GE174Universal...
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
