Question about Maytag PYE2300AY Electric Dryer
Matage Dryer LDE 7600 dried two loads today and then just quit turning on the third load. The heat is working, motor sounds like it is working but the drum quit turning. Can I fix it myself?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the drum quit turning and the motor is running, then the belt has broke. Replace the belt with this part. Here is a video to walk you thru the repair.
Posted on Jan 03, 2011
DV328AEW/XAA dries one load and quits until cool
Typical 'motor over heat' or weak thermostat problem. Try starting the dryer just after it over heats. What happens..A humming sound?...motor is overheating and seized up....if quiet, could be motor as well. Check that your dryer vents are open and clear.
Oct 15, 2013 | Samsung Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
We have a Fridgidaire Affinity front load dryer. It was bought used in good condition. It has been working fine for a week but today it only dried a load half way and then when I tried to start the drying...
There is little to go wrong in these - and it's the electronics that confuses thngs.
Check the drum is free to turn, and that it drives the motor. Turn off - unplug, wait, then plug back in and try again.
If it's a no-go, you have to unplug and check inside - use a meter on the motor to check it's ok, and check heating elements.
Check door catch is working.
Check thermoststs work.
If all these parts are ok - you need a new control board - it's the only thing left.
Dec 27, 2010 | Frigidaire ATF6000ES Front Load Washer
The dryer heats on and off. Sounds to be laboring to turn the drum. Service tech came out and did not know how to fix or approach the problem with why the dryer heats and dries a load and then may not on...
drum roller,drum glides, or idler assemblage which is located next to motor(might be motor going out). Here is a website that will help:
for glides/roller: http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
for idler/motor: http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Replaced heating element for dryer.Dryer started heating for one load. Then quit heating,found wire disconnected-reattatched wire and dryer was working.Now one small load later , dryer quit drying-no hot...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
138 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
