Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I cleaned out fridge and freezer and turned frideg back on and it keeps shorting the power. I have tried other power points, but it stiull shorts out. HELP
  • 1,557 Answers
You have an earth to pos neg feed fail this fault has no easy fix and it will need to be repaired by a servcie tech have them test the defrost element first this is the most common earth fault if it has a manual defrost switch turn it untill its off defrost cycle try it then if it runs this will asure its the defrost element but dont use the fridge it still has a downed cable
best of luck
Posted on Jan 03, 2011
My WHirlpool WFS1071BW when turned on keep tripping the fuse.
probably motor short or pump motor short washing machine service man or lady is required
Sep 27, 2014 | Washing Machines
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I woke up one morning and the fridge is not working but the freezer is working great. The fridge does not want to get any cooler than it used to be, it is not keeping our products cold. My fridge freezer...
the damper vent door between the freezer and fridge has stuck shut due to being frozen,you need to remove the freezer wall on the inside rear area to see if this door is shut and try to get it to move,also make sure the evaporator fan is running too so air gets moved from the freezer to the frideg
May 19, 2011 | Hotpoint RFA51 Bottom Freezer Refrigerator
Frigidaire fridge freezer not getting cold
Louise, this is a big area. I would switch off the fridge, look at the back where you see the" box things". You should see a timer which is white or black (wires comming out of it).. It has a short type of knob which can be turned manually clockwise.. Turn about a 1/4 turn then try and switch on again. If not, thermostat will be the problem. Assuming you never disrupted any wires.
Nov 13, 2009 | Frigidaire Freezers
Bosch fridge freezer turns itself off
turn it off and back on gets it working again? are you using the thermostat to turn it off and on? If so, Do it slow and try to feel and irregulatities. Like looseness at any point or possible the whole switch is turning and you aren't getting the setting you want. If so, the thermostat is doing it.
May 18, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge got wet, now it sparks and shorts power
I suggest you unplug the fridge. If possible you can then open the wiring connection cover on the compressor (where the supply cable connects) and check what is causing the short circuit. Probably when moist there was a short circuit due to water but this may have burned some of the wiring. This will be quite visible and easy to repair with a bit of insulation tape.
Apr 15, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Fridge shorts power out
From your description it sounds like a short in the defrost heater circuit. It would normally be a repairable item. You may want to consider the age of the refrigerator before getting into the repairs.
Aug 24, 2008 | Refrigerators
Fridge is not cold but the light will turn on...
Try to uplug it for a few minutes then plug back in. Let us know if the compressor and fan kick on then otherwise we'll have to give more advice on where to look, etc.
Dec 24, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
