Question about Marantz CC-4300 5-Disc CD Changer
Cc4300 It is written ERROR on the interface. The cd tray doesn't open. Is there a way to reset the system ?
A problem with epson artisan 810
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 08, 2014 | Epson Artisan 810 AllInOne InkJet Printer
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
LG GH22NS70 Super multi DVD Rewriter just used
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
Jul 17, 2011 | LG GH22NS70 Super Multi 22X SATA DVD...
The tray will not open,have tried to pull it open,but get message saying,"tray error"
in this case your cd player is absolutely ok just motor of tray has damaged just open your cd player and replace dc motor you can buy it from any electronics equipment shop..just read the specification which is written on motor and then buy it...
Mar 14, 2011 | Audio Players & Recorders
CD/DVD door will not open
I have the same problem once in a while usually after a disk read error. If you power off the system (unplug it) it will reset and the door will open.
Jul 13, 2009 | Bose Lifestyle 18 System
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
Marantz CC-4300 5-Disc CD Changer Logo
76 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
