Question about Car Audio & Video
Reference Class A 6.0 with entire bank of 18 capacitors swelled up and 3 neighboring resistors charred. I have the ability to replace parts but was wondering what may have caused this or if something else may need to be replaced. I lent this amp to a friend about 10 years ago and just got it back--- of course he knows nothing about how it happened.
  • Khan Powell Jan 03, 2011
    Thanks for responding. Are you familiar with this particular model of amp? Low ESR capacitors are used from the factory. I am looking for what may have caused this so I don't find and install a bunch of parts only to see them blow also. Any suggestions?
    Thanks again,
    khan
  • 11,361 Answers
It is typical caps failure in the switching power supply due to high ESR that causes the caps temp to rise up. You should make sure to replace tthem with LOW ESR type. See pictures of bad caps in my albums.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jan 03, 2011
  • Bud Martin
    Bud Martin Jan 05, 2011
    They may have used low quality Low ESR type, as you can see from my pictures in my bad caps album. Even MAC use low quality caps on its mother board and power supplies, same for DELL and other PC makers, there are millions of bad caps in circulation.
    You can learn more here: www.badcaps.net
    I only use PANASONIC FM/FC series.
Visio VX32L has a black screen, appears to power on but picture.
Any swelling on a cap is bad sometime you wont see swelling ontop sometimes its on the bottom, I suggest replacing those caps then try again make sure you discharge the caps as well.
Also make sure its the right caps too!
1000uf 6.3volts or something like that. Ebay a good source for caps and amazon.
Dec 15, 2015 | Televison & Video
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
Wipes warmer will not turn on. It is brand new tried itmin several different plugs.
The HV Electrolytic Capacitor between the Resonance Transformer and the Resistor Bank (all of which are located in the power supply) is most likely blown. If this is the case, there will be light brown or dark yellow discoloration on the surface of the capacitor. Since it is new I would recommend taking it back and getting the entire thing replaced.
Apr 16, 2011 | Prince Lionheart Travel Wipes Warmer -...
BLOWING FUSES INSIDE UNIT. REPLACE FUSE. BLOWS INSTANTLY
hello because theres a dead short and the fuse is doing it's job could be number of thing that are wrong. 1 shorted diodes/ 2 shorted output transistor/ 3 shorted resistors /4 blown or swelled capacitors get an engineer to check it out good luck
regards
shaun
Dec 27, 2010 | JVC TH-A10 System
My mitsubishi tv won't turn on
Bad capacitors that chassis is famous for numerous capacitors failing without notice.Every circuit board within the entire chasis will have numerous capacitors that will be swelled up and leaking which will require that they be replaced. You can get the repair kits for the V26 Chasis at www.tvrepairworld.com which contain instructions on the CDs along with the replacement parts.
Dec 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
X+4+2/3=6
I THINK YOU WANT TO KNOW THE VALUE OF X
X+4+2/3 = 6
(3X +12+2)/3 = 6
3X+14 = 3*6
3X + 14 =18
3X = 18 - 14
3X = 4
X = 4/3
X = 1.333 this is answer
Nov 04, 2009 | SoftMath Algebrator - Algebra Homework...
I have a Bernina Sewing Machine with a Control Board that smoked
Bernina does not sell individual components for PCBs, rather they have an exchange program for the entire board. But you have nothing to lose and much money to save if you can obtain the parts and replace them yourself. You should be able to get the caps and resistors from any electronics supply.
Oct 01, 2009 | Sewing Machines
Same problem here.
If you're only reading .18 volts DC at the charger itself, then it's time to replace the charger.
It's probably some inexpensive Electrolytic Capacitors inside the charger that have bit the dust.
Here's info about Electrolytic Capacitors,
1.http://en.wikipedia.org/wiki/Capacitor_plague
2.http://www.capacitorlab.com/visible-failures/index.htm
Both sites relate to computer motherboards and computer power supply's, but know, that there has been a problem with 'Caps' for all kinds of electronic components, no matter what they are, therefore these same visual signs of failure apply. (Sorry about the run on sentence!)
3.http://www.absoluteastronomy.com/topics/Capacitor_plague (Read the entire article, and my statement above will become more clear)
Jul 13, 2009 | Black & Decker 14.4 Volt Battery Charger...
Avm 3259 picture problem
Vcc is on Pin 6 of the vert. output IC so you can trace that back to it's feed resistor (not sure the location number but you can find it easily by following the circuit trace). Depending on what your problem is you may need to replace some electrolytic capacitors as well. Follow pin 7(pump up) back to it's electrolytic cap. and look for swelling or bulging. Look for other bulged capacitors in the vertical section. You may also identify a bad resistor by a discolored look but not always, if in doubt meter it.
Let me know if you need some more info.
Oct 03, 2008 | Sanyo AVM-3259S TV
Convergence Resistors
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Mar 24, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
