Question about Toshiba Satellite A135-S2276 Notebook
I have a toshiba a135-s2276 how do i reset to out of box settings. ive tried the f 10, the f 12 the holding down 0 and the hitting f 8 repeatly i dont have a disk. help please
P2RIPHIRIQUE AUDIO
Posted on Jan 09, 2011
Toshiba a135-s2276 will not boot
First try to reset bios by make short in cmos battery. If it doesnt work turn it off then remove battery, connect adopter power then turn it on, also if doest work press number one hold then turn it on.
Apr 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Sate276llite A135-S2276 laptop won't boot.
if unable to turn on the screen just lights flashing
RAM is faulty try replacing it , if u have two chips try installing one by one see if it helps
or
if it shows some text on screen and try to boot and u can access bios then
ur OS has corrupted two reasons for that
1. due to virus, malware spyware, etc
2. Hard Disk is getting weak wants replacement
solution first try to re install the OS if u find it difficult to do so then my friend ur hard disk needs replacement
factory reset procedure
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls rate me FIXYA if i fixed ur problem
Feb 19, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a tosiba sattlite lap top that i frogot the pass word on
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/208408-solved-how-do-reset-bios-password-toshiba-satellite-a135-s2276.html
Re: How Do Reset Bios Password In Toshiba Satellite A135-s2276 ?
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
you will see what looks like the letter T over a U.
Using a metal paper clip short the U to the Silver 1/4"
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
and test start laptop. you should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding
the ground(that blob of solder about 1/8"dia on both
ends of the "silkscreen chip outline" This is about as simple as i can break it down
tell please ! i ready for do this now ...
Dec 27, 2008 | Toshiba Satellite A135-S2386 Notebook
BIOS Password reset on Toshiba A135-S2276
Use a boot disk such as, the Ultimate Boot CD or the Ultimate Boot CD for Windows if you don't need a BIOS password. If you do, try Toshiba.
Oct 20, 2008 | Toshiba Satellite A135-S2276 Notebook
Default bios password toshiba satellite a135-s2276
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jun 03, 2008 | Toshiba Satellite A135 Notebook
STICKEY KEYS!
heres the quick version:
hold down both shift keys, it should either disable it or pop up a message to disable it, hit escape, not cancel...
control panel, accessibility options, keyboard, click settings near filterkeys, uncheck use shortcut, click ok.. check the boxes for use filter toggle and stickey keys, hit applyuncheck them all and hit apply again... if this doesnt fix it, read on..
create a blank text file on your desktop named disable.reg or something similar, and paste the portion between the --------'s into it:
[HKEY_CURRENT_USER\Control Panel\Accessibility]
[HKEY_CURRENT_USER\Control Panel\Accessibility\Blind Access]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\HighContrast]
"Flags"="122"
"High Contrast Scheme"="High Contrast Black (large)"
"Volital HC Scheme"="High Contrast Black (large)"
[HKEY_CURRENT_USER\Control Panel\Accessibility\Keyboard Preference]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\Keyboard Response]
"AutoRepeatDelay"="1000"
"AutoRepeatRate"="500"
"BounceTime"="0"
"DelayBeforeAcceptance"="1000"
"Flags"="122"
"Last BounceKey Setting"=dword:000001f4
"Last Valid Delay"=dword:000003e8
"Last Valid Repeat"=dword:000001f4
"Last Valid Wait"=dword:000003e8
[HKEY_CURRENT_USER\Control Panel\Accessibility\MouseKeys]
"Flags"="58"
"MaximumSpeed"="80"
"TimeToMaximumSpeed"="3000"
[HKEY_CURRENT_USER\Control Panel\Accessibility\SerialKeys]
[HKEY_CURRENT_USER\Control Panel\Accessibility\ShowSounds]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\SoundSentry]
"Flags"="2"
"FSTextEffect"="0"
"WindowsEffect"="0"
"TextEffect"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\StickyKeys]
"Flags"="506"
[HKEY_CURRENT_USER\Control Panel\Accessibility\TimeOut]
"Flags"="2"
"TimeToWait"="300000"
[HKEY_CURRENT_USER\Control Panel\Accessibility\ToggleKeys]
"Flags"="58"
make sure not to paste the ------'s.. anytime it enables itself, just doubleclick the file, it should disable it for you.
hope this helps
trin
Nov 16, 2007 | Toshiba Satellite A135-S2276 Notebook
Reset Toshiba Labtop A135-S2276 Bios Password
see the below post for a possible solution http://www.fixya.com/support/t187128-toshiba_m105_s3004_bios_password
Aug 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
