Question about Apple MacBook Mac Notebook
Battery Cycle count of 801 what does this mean good or bad?
  • 536 Answers
It means that you've probably had your Macbook about 4 or 5 years and have recharged the battery in full 801 times.
This is neither good or bad. It's just a fact used to determine how much you've used your Macbook on battery.
As long as you are getting an acceptable length of time while using your Macbook on battery, then you should be fine. At some point in the future, the battery will begin to fail and last for shorter and shorter amounts of time and eventually may even drop-out completely. At that point, you'll either buy a new battery for your Macbook from Apple or buy a new Macbook.
If this answer helps you to understand the cycle count (and it should), please rate my answer as either 3 or 4 thumbs-up (1 or 2 thumbs up are like saying my answer was useless or barely appropriate)
Thanks for using FixYa and Happy New Year!
Posted on Jan 03, 2011
Ndrive g800r battery charging
Li-ion battery packs in laptops have a circuit board that prevents overcharging. Unfortunately it also keeps count of the number of times the battery pack has been through a charge/discharge cycle and eventhough the batteries maybe still be good; IT keeps batteries from accepting a full charge and and that is why they will not keep a charge for as long as they did when new. Also if any battery in the pack goes bad it effects the whole pack because of the way they are assembled.
May 19, 2017 | Computers & Internet
My laptop won't charge. It was working when plugged in and now it won't even do that. Will replacing the battery fix my problem?
It sounds like your battery and your charger are not working. Changing the battery should help, but you should first check to see if you are getting voltage to the laptop. Does the green light on the magnetic end (the end that plugs into laptop) light up when plugged in? If so, your charger is working. You should be able to turn on the laptop with or without a battery (even a dead battery) with a good power supply. If you can turn it on, check to see the number of battery cycles you currently have.
Follow these steps to access information about your Mac notebook battery including the cycle count:
  1. Your first step will vary depending on which version of Mac OS X you are using:
    • OS X Snow Leopard v10.6.8 or earlier: Open Apple System Profiler by choosing "About this Mac" from the Apple menu. Then, click More Info.
    • OS X Lion v10.7 or later: Open System Information by choosing "About this Mac" from the Apple menu. Click System Report.
  2. Click Power in the Contents list (under the Hardware section as shown below).
  3. The current cycle count is listed under the Battery Information section.
Take notice of Full Charge Capacity (mAh) on your machine. It should be close to the number shown above. If it is much lower than that and/or the cycle count is above 1000, it is time to replace the battery. I hope this helps.
Mac notebooks Determining battery cycle count
May 15, 2014 | Apple Customized 15" MacBook Pro Laptop...
What are error codes 801 301 3D and 800 1000A on the Sony Playstation 3 console. I need help realy bad. Enyone that awnsers will have there questions awnserd. Thanks for reading.
Error 801 301 3D is due to internet connection issues.
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. ps3 , use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
And 800 1000A error means that you cannot download from the sony store. hence the connection problems from your first error.
Hope this helps you.
Correct? recommendation and vote would be aw some!
thanks.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
At the spin cycle it shuts dwn and has Lr on the screen when I shut it off to just use spin cycle it does a count down but not the spin then Lr comes up again
Hi
Thanks for using FixYa. Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
DELL W5300 PRINTER - GETTING THE MAINTENANCE COUNT
It is like your oil light coming on. It means the printer has reached its pages count where they recommend changing the maint kit. (usually new fuser / rollers). If print quality good - let it go - it will work for another 10,000 pages or so. If print quality bad (streaks and rough spots) it needs a new fuser. After replacing the kit you reset the count to zero and it start counting again.
Feb 27, 2009 | Office Equipment & Supplies
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Looking for a manual 801 nikon
Do you mean the F-801? Then go to http://www.butkus.org/chinon/nikon.htm
Aug 16, 2008 | Nikon Cameras
X41 Tablet PC the battery shows good but computer will not work
Some times a battery can pickup a dead short, and even though it shows a charge it will not work. The other possibilty is the power management chip on the mother board. This chip allows the computer to charge the battery and switch from battery to AC. (Right now I have a Thinkpad that will only run on battery, bad PM chip) Try replacing the battery first, if that doesn't work, then unfortunately the motherboard will have to be replaced.
May 24, 2008 | IBM ThinkPad T40 2373 Notebook
Apple MacBook Mac Notebook Logo
604 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
