Question about Dryers
My GE gas dryer has the most annoying buzz when the cycle is over. Is there any way to disconnect this feature, it is a horrible noise.
  • 1,557 Answers
There is a small pizo on the circuit board take a soldering iron and remove it
it looks like this could be yellow or white as well
Posted on Jan 03, 2011
Maytag gas dryer. Loud buzzing sound when flame comes on. Buzzing stops when gas valve off. Replaced solenoids twice. Dryer works but the buzzing is annoying. Do I need to replace gas valve assembly?
While you are hearing the buzzing, tap the gas valve (gently) to find out whether the buzzing changes. If so, the valve is the culprit.
Feb 18, 2017 | Maytag Dryers
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
My gas dryer will not heat, but makes a funny buzzing type noise as if it is trying to heat/ignite. On the air dry cycle, there is no noise at all (also no heat, but that's ok). After letting it run for...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 19, 2010 | GE Profile DPSB620GCWW Gas Dryer
Buzzing noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | Samsung DV419AGW Dryer
The dryer is making a horrible noise!
heatman101
3434gd
Jun 12, 2010 | GE DBXR463GD Gas Dryer
Noise in brand new GE dryer
HI not the gas line that should be fine there is something stuck in your blower fan i would say if it went wrong after one hour they should come right back to fix it
Jul 13, 2009 | GE DCVH515GF Gas Dryer
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryers Logo
Top Dryers Experts
