9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger Power Supply. AC Input 100V-240V 50-60Hz;DC Output. Industry Quality : Over Voltage Protection, Over Heat Protection. Brand New Adapter, 100% Compatible. Warranty:1 year warranty, 30 day money back guarantee. Shipping from USA !
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger ... D'Addario Accessories PW-CT-9V DC Power Adapter - Minimize Need to ...
Rating: 4.3 · 15 reviews
Are you telling us that you are using a Bluetooth adapter to try to connect your ASUS N50Vn laptop.to a wireless network??? For that you need a (wireless) network adapter (it plugs into an available USB port on your laptop. like the BT adapter), not a Bluetooth adapter.
You probably need a new one, you could try to get a replacement from casio or try to get an after marked one. They sell the adapters that have multiple ends and voltage settings, if you go this way you need to be careful. Look at the old adapter, you need to know how the voltage (Will probably be between 6 and 12) and the current which is measures in amps (A). Will probably look something like this:
9V ~ 2.5A
you need to make sure that the new adapter has the SAME voltage (V). Having a higher or lower voltage can and probably will damage the keyboard, so it is important that this is the same. As for the current (A) you do not need an adapter with the same number here, but it is a good idea to use the original number as a minimum. The current is the measurement of how much electricity the adapter can supply to the unit, if the number is too low, it could potentially damage the keyboard and the adapter, but if its higher there is no problem. And obviously you need the right end on your new adapter to fit your keyboard. Say you found a new adapter with the correct voltage and current but the wrong end, if you were ambitious you could cut the end of your old adapter and splice it on to your new one, however, as these adapters are supplying dc current you need to make sure you do not switch the polarity (positive and negative), if you do damage will may ensue. You will need a multimeter to check the polarity of the new adapter make sure you splice the right wires together. (you will need to know what the keyboard need, sometimes it is indicated on the back near where the power plugs in.
I am starting to ramble, if you do intend to get another adapter and splice I would be happy to help you the rest of the way, but i will end it here for now.
That depends on where you're coming from. The mains in the UK are 230 volts. If your adapter is already working in the 220-240 volt range then you won't need a voltage adapter. If your adapter is designed for the 100-120 range then you will need a voltage adapter.
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers.... but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
To install the adapter you will definately need a disc. because the adapter will not work without the Drivers. Drivers are very important for the adapter. One more thing that if you have WIN XP or VISTA then you don't need the set up utility but still you need the drivers for the adapter. If you do not have the disc. You can download the drivers from the manufacturer's web site and install the drivers for your adapter. Click her for more info about networking
You dont need your wireless adapter to setup your laptop however if you are going to setup or use your laptop to connect to a wireless connection you need your wireless adapter
