Question about Samsung RB2155SH Bottom Freezer Refrigerator
How do I figure out my model number if I lost the owners manual and I need to get a new bottom tray on the door that holds all of the milk and OJ?
  • 472 Answers
Should be a sticker on the inside of the fresh food side (refrigerator side) i have a samsung and mine is when you open the door on the left wall up front... some are on right wall and some are actually on ceiling of refrigerator wall.... this should be all you need and then get on line and typre in samsung refrigerator parts a list of appliance parts dealers will come up.....good luck to you
Posted on Jan 03, 2011
Can' t remove milk dispenser retainer cva4062 to clean because milk will not dispense. Machine is brand new , used 2 times
see the owner manual on how to manualy clean the pipe work
i do it on a weekly basis
u have to remove the face plate pull down the dispenser nozels and the open the door and remove the mild flask and the remove the milk pipes
run the bristels and run some water trough
Nov 03, 2012 | Miele Coffee System
Key symbol showing unable to use machine
Child Lock has been activated. Since differerent model require differerent key press sequences all I can tell you without your model number is to find your owners manual and look up the finctions of the child lock so you can de-activate it.
If you can not find an owners manual I will need a "make and model" "type or series" if you can not get access to the model number because the door is locked. Usually a model number is located on the upper kick / toe panel at the bottom of the unit under the door. I need some thing to begin any manual searches so that we can get this resolved.
Thanks for choosing FixYa,
Kelly
Jul 30, 2011 | Washing Machines
I bought a Maytag Refrigerator - Model - Quiet Series 300 - It was purchased in 2007 first, then after 5 repairs Maytag replace with brand new unit. Once again, we are experiencing the same issues, the...
Maytag is now owned by Whirlpool who have moved production to Mexico (a**h**le*) anyhow this unit uses thermistors connected to the electronic control board instead of thermostats.
Please furnish the full model and serial number and I will see what information I can supply.
May 04, 2011 | Refrigerators
Tail light is burned out on tail light. I have the bulbs but can't figure out how to remove and replace burned out light.
  1. Check with your local auto parts store or look in your owner's manual to find the proper model number of the replacement tail light globe.
  2. Open your trunk or lift your hatchback. Find the cover just on the inside of your vehicle next to the burnt-out bulb.
  3. Turn the two latches counterclockwise to open them so the cover may be removed. In most cases you can turn the latches with your fingers; in some cases you may need a coin or a slot screwdriver to turn them. Remove the cover.
  4. Press the tabs that allow you to remove the tray that holds the tail light globes. There are four tabs on most VW models. Each tab must be depressed to release the tray. Pull the tray out a few inches, as far as the wiring allows.
  5. Press down slightly on the burned-out globe and turn it counterclockwise with your thumb and fingers. It should release easily and then pull straight out. Push the replacement bulb in and turn it clockwise until it locks in place.
  6. Snap the tail light tray back in place. The tray should simply push back into place and the four tabs should "snap" into their locked position. Replace the door cover and turn the door locks clockwise. Test your bulb to see that it is working.
Good Luck
Nov 20, 2010 | 2004 Volkswagen Beetle
Lost instruction manual in the middle of assembly need help now please.. can't figure out the pully system...
To get an owners manual you can one of two things. First, go to www.iconservice.com in the manuals link. There you can type your model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a hardcopy but it will cost around $20 with tax and shipping. The number is 1-800-999-3756.
Aug 16, 2010 | Pro-Fit Exercise & Fitness
Milk boiled over and leaked into glass window on oven door. Can I take it apart to clean it? Oven is self cleaning..will this be a problem?
Yes...you can disassemble. Consult the owner's manual for door removal instructions. The manual can be found at this link with the instructions for removing the door on page 22.
JBP78 Owner's Manual
The link below will show you the door construction. Lay them out in the order they came apart. Make notes if you think you'll get lost. It will be no problem if you reassemble correctly. Good Luck
JBP78 Door Assembly Breakdown
Sep 12, 2009 | GE Spectra JBP78 Electric Kitchen Range
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
LiftMaster Garage Door Opener
IF YOU ARE TALKING ABOUT THE ROLLER ON THE DOOR - THE TRACK IS TOO WIDE ALLOWING THE ROLLER TO COME OUT. USE THE CLAW END OF A HAMMER TAP THE TRACK MOUNTING BRACKET AT THE WALL TO MOVE THE TRACK IN CLOSER TO THE EDGE OF THE DOOR
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Samsung RB2155SH Bottom Freezer Refrigerator Logo
71 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
