Question about Dewalt Drills
My dw272 type4 don't work with new brushes - Dewalt Drills
  • 1,557 Answers
In most cases we have seen with dewalt drills the fault is corrosion around the power points to the motor they snap off if this is not the case then it will be the trigger switch
Posted on Jan 03, 2011
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Saw motor is sparking
Most of the time sparks in these tools come from where the brushes make contact with the armature. Some causes for sparks are: The brushes are worn down to where they don't make firm contact with the armature. Brush springs overheated and no longer push the brush down on the armature. The comutator on the armature is damaged and causes the brushes to spark excessivly. You can take it apart and try to find which parts are hurt but I don't know if any Clarke Power Products parts are still available. The company went out of business around 2009 so you'd have to find someone with left over parts. It may be easier to buy new and go with a name brand and new warranty.
Jan 22, 2012 | Clarke Power Products Saws
Want manual HS80 type4
Would this be for the Black & Decker HS800 Flavor Scenter Handy Steamer? The Use & Care Manual can be found online here:
http://useandcaremanuals.com/pdf/HS80035.pdf
Dec 16, 2011 | Kitchen Appliances - Others
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
New dremel 4000 used very little is missing the brushes and whatever else goes in the brush hole. found the cap laying on the table with no other parts. what do I need to replace???
Dremel has all their replacement parts right on the shelf at walmart, brushes, caps, chucks, the works. You found the cap, the brush is a little carbon square attached to a wire with a spring on it. Real simple. Buy a pair and get it fixed up. My favorite tool.
Jun 25, 2010 | Dremel 4000230 High Performance Rotary...
DW272 switch wiring
I would go to the mfr's website and download or look at the wiring breakdown. All these companies have breakdowns online
Nov 13, 2008 | Drills
Drills Logo
156 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
