Netbook will not connect to wifi. Have tried to do it at 3 different locations and still no results unless plugged into router directly with an ethernet cable.
  • 600 Answers
Try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router? choose VIEW all wireless connections and choose the one you want..
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Posted on Jan 03, 2011
My next book can't connect to WiFi because Mac and IP address is unavailable. What do I do
1) Turn off your netbook
2) Power off the router by unplugging it
3) Power off your cable or DSL modem (if different from your router) by unplugging it
4) Power on your cable or DSL modem and wait for the blinking lights to "stabilize" a bit
5) Power on your router (if different from your cable or DSL modem) by plugging it in and wait for the lights to stabilize a bit
6) Turn on your netbook
7) Test connectivity
Feb 01, 2015 | Computers & Internet
There is free internet service with an unsecure wifi at my apartment building. How do I boost the signal so I can get optimal results with so many freeloaders hogging the internet?
Bummer deal! Try to reinstall the wifi. And try and move it to a different location - to see if that helps. Try higher in the air for more direct signal reach. Hope this helps.
Dec 07, 2014 | Computers & Internet
No wifi on Netbook E70006 Tim Hortons Serie's
shut down laptop, unplug, remove battery, Reboot Moden/router , allow it to selftest, plug in laptop, reboot.
Dec 17, 2012 | Computers & Internet
Slow wifi on Sony Pcg-21313l
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Nov 15, 2012 | Sony Vaio Netbook 1gb 60gb Windows 7 Home...
Wifi won't work been have this computer for my son since christmas still can not get a hold of anyone on the phone try just about everyday please help (WiFi Won't Work)
1. have you connected the Netbook physically to the router
2. Is the netbook listed in the router as wireless device ( allowed to connect wirelessly.\
3. if the device allowed to connect via the firewall.
4. Have you read the Netbook manual to connect wireless to a allow connection in your area.
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
Jun 21, 2011 | Sylvania G-Netbook
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
I am trying to connect my netbook to the internet and it won't connect because it can't find an ip address i have looked and tried everything what do i need to do?
netbook router ethernet or wireless
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Mar 10, 2011 | Computers & Internet
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
Server not found
you will need to enable your wifi, sometimes there will be a switch on the front of the laptop and sometimes its a key combo (Fn + one of the F keys ex F11) then you should be able to connect to your router/SSID and be back on the net. your getting the server not found because your not connected.
Sep 09, 2009 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
