Question about Acer V193 Monitor
My ACER Monitor shows green striped pixels wherever there is BLACK colors on the screen. Eg: Shadows in a video game, wallpaper with black background. It happens on and off, but the more it happens the longer the pixelation stays. Is there a way to correct this?
  • Acer Master
  • 6,771 Answers
The problem is either the video graphics card in the computer or the monitor, if you have a backup monitor check the computer first, if the same problem persists the video graphics card is bad. If however the second monitor is fine, then your monitor is the problem, The screen is breaking down, if you have a detachable video cable, sub it for another to make sure there are no issues,if okay your monitor is the problem and not cost effective for repair.
Posted on Jan 03, 2011
Vizio VF550XVT1A have green pixels wherever there should be black on screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 25, 2017 | Vizio Televison & Video
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
I HAVE RED DOTS ALL OVER ANY BLACK COLOR OF THE PICTURE
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
Nov 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Feb 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
3 pixel wide stripe on lcd
Hi Casey,
If the problem is getting worse, than either the pixels are dying (so to speak) or you might have a problem with the monitor's screen.
Unfortunately, if either of the above are true, then the only way to fix it would be to replace the screen, which can be quite expensive. If you agree that this is the problem then you'd be better off getting a new monitor instead of spending money to get it repaired.
Good Luck.
Jun 07, 2009 | Acer AL1711 17" LCD Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
Green shadows in dark scenes
You should contact Service Center to resolve this issue.
Jan 22, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Acer V193 Monitor Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
