Question about Samsung WF337AA Front Load Washer
How to remove mold and mildew stain build up on rubber liner in washer; also recently started noticing an oder. Please help! Thanks.
2 Suggested Answers
  • 4090 Answers
SOURCE: cleaning a front load washer for mold and mmildew
What's the question?
Use a mild bleach
heres the solution from washing machine manuals, dont know why fuses and powerre included in this...
odor in washer
• Water supply taps are not
open fully.
• Water line hoses are kinked,
pinched, or bent.
• Water inlet filters are clogged.
• Water pressure to tap or
house is too low.
• Power cord is not properly
plugged in.
• House fuse is blown, circuit
breaker has tripped, or power
outage has occurred.
• The door is not closed
properly.
• Incorrect or too much
detergent has been used.
• Inside of tub not cleaned
properly.
• Make sure that the water taps are open fully.
• Make sure the hoses are not kinked or pinched. Be
careful when moving the washer.
• Clean the inlet filters. See the Care and Cleaning
section.
• Check another faucet in the house to make sure that
household water pressure is adequate.
• Make sure that the plug is plugged securely into a
grounded, 3-prong, 120-VAC, 60-Hz. outlet.
• Reset circuit breaker or replace fuse. Do not increase
fuse capacity. If the problem is a circuit overload,
have it corrected by a qualified electrician.
• Make sure that the door is closed properly and press
the START/PAUSE button. After starting a cycle, it
may take a few moments before the drum begins to
turn or spin. The washer will not spin unless the door
is locked (DOOR LOCK will appear in the display).
• If the door is closed and locked and the open door
error message is displayed, call for service.
• Use only HE (High-Efficiency) detergent in accordance with the
manufacturer’s instructions.
• Run the TUB CLEAN cycle regularly. Be sure to wipe around and
under the door seal frequently.
• Clean around door seal/glass to prevent odor or mildew:
1. wipe dry the door seal/glass and the door opening area
2. wipe around the inner drum/door seal and the lower door seal
Posted on Aug 20, 2009
Mildew in washer
Hi Meredith, this is AP!
I understand you are struggling with mold spreading in your Frigidaire dishwasher, model PLD2560LCC. The average useful life of a dishwasher is about 13 years, so I would attempt to get a few more years from the dishwasher if you can. Chlorine bleach kills mold and helps remove most mildew stains. Dilute 1 cup of bleach in a gallon of water and scrub the interior of the machine with a stiff brush. Use a toothbrush to get in narrow areas, such as around door gaskets. Wear gloves to protect your hands when you use bleach, and also avoid mixing bleach with any other cleaning product. Run the dishwasher empty after cleaning it to rinse out the bleach residue. If stains remain after mold removal, scrub them away gently with a damp rag and mild scouring powder.
Or you could run a cycle with no dishes. Once the dishwasher has completed its initial fill, add 1 cup of white vinegar and complete the cycle. If you find that removes the mold I would open the dishwasher door after each use and allow it to dry out completely before closing it to prevent mold growth. Moisture, bits of food and a warm environment can lead to unwanted mold growth. If you won't be using the dishwasher for a while, such as when leaving for vacation, leave the door open while you are gone to ensure no trapped moisture leads to a mold or mildew problem.
I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Was cleaning rubber gasket for mold and noticed when I cleaned inside outer lip of steel drum a lot of brown sludge-is this grease for drum or is this build-up of some sort that should be cleaned? Also-do...
    The brown sludge you are finding should NOT be grease as the bearings for the drum are sealed. This may be soap scum build up, and a combination of mold or mildew if you have been leaving the door shut between washes. It is strongly recommended by the manufacturer that you leave the door open when not in use to allow the drum air out. This aids in preventing mold, mildew and odors. The following link explains some of the common causes of front loader odors and how to remedy the problem:
    http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
    As far as the water fill hoses are concerned, the hoses are usually good for about 5-10 years (rubber), 10-15 years (stainless steel). They usually only require replacement if the rubber begins to crack or dry rot and/or begin leaking. A general inspection of the entire length of hose, cleaning the sediment screens in the ends of the hoses (if equipped) and replacing the gasket at the fitting will extend the life of the hoses. Replacing the hose has nothing to do with preventing odors. Odors are generally caused by not leaving the tub open to air out, using too much (or improper) detergent which causes soap scum build up, or a clogged drain trap. The following link explains how to access and clean out the drain trap:
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
    I personally own a washer similar to yours and have never had any problems with mold, mildew, or odors, by following this regiment. If you have any questions or concerns, please post back and let me know. I hope you find this information helpful.
    Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer stinks from using goof off stain remover on clothes
    The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
    PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
    CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
    LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
    NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 08, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    The loading door gasket-- the big rubber liner doesn't drain
    Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
    Feb 03, 2010 | Washing Machines
    Build up of mold/mildew on rubber gasket. Makes
    you need to purchase a package of 3 tablets called AFRESH at your local appliance parts store and follow the directions on the package. also, leaving the door open a bit after each wash will help.
    Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Lots of mold and mildew stains on front door seal.
    Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
    Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
    Maytag HE 4t/ Kenmore Elite Smartwash Serial# CST0411376 MODEL# 11045088403 TYPE 199 712 CN/AP MY WASHER HAS A AWFUL ODOR INSIDE THE TUB. I HAVE CLEANED IT OUT WITH ALL KINDS OF CLEANERS TO TRY...
    The following link provides guidance on how to maintain a front loader to keep the mold, mildew and odor away:
    http://www.fixya.com/support/r513372-front_loader_mildew_odor
    These are recommendations provided by the manufacturer. Most important of all, keep the rubber bellow clean and clear of debris and make sure you leave the door slightly open when not in use. This will minimize the build up of any mold or mildew and allow the tub to air out. The odor typically comes from the the residual water that stays in the wash tub under the basket and small articles of clothing getting stuck in the rubber folds of the door bellow. (I once found 17 socks stuck in a customer's washer and they wondered why it smelled so bad). NOTE: It is NORMAL to have residual water in the wash tub. If you do not routinely use a hot water setting, run the washer on a sanitary cycle about once a week, or so, with a small amount of bleach to get rid of any bacteria. Since some users conserve and only wash in cold water, they do not bacteria get rid of any bacteria inside the wash tub. I personally own one of these washers and have never had any odor or mildew problems in 8 years by following this simple advice. If you have any further questions/concerns please let me know. I hope this helps you.
    Aug 06, 2008 | Washing Machines
    Maytag Nepture washer Model MAH 5500 boot mildew
    The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
    Jul 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
    MILDEW ODER THAT WILL NOT LEAVE?
    Fear not there is new product on the market designed just for your very need. www.affresh.com . but lets go over a few steps first. It actually for the most part ,not mold/mildew although it seems that way. First and foremost you MUST MUST use an HE detergent. not just less of regular detergent but actual HE detergent (and only 2-3 tablespoons of that even) Cut back on the amount of fabric softener that your using (if any) and leaving the door ajar between wash cycles improves air flow through the tub assy. Finding that its actually been a build up of extra detergent not breaking down completely giving of the odors. this product will help!!!!
    Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Samsung WF337AA Front Load Washer Logo
    235 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
